Has anyone done this successfully, meaning you can put the same headliner back up? Driving this are 4 rusty holes in the roof from my factory rack that I just removed. I want to weld them up, but thinking pulling the headliner down would be a bit safer that trying to weld with it still installed. And it needs a good cleaning anyway..
I pulled the headliner from my 97 and successfully reinstalled it. I was real careful. I am making the assumption the 95 has a rigid foam headliner like mine. If so, just go real slow and be careful.
I removed the HL in my 95 for a sunroof replacement. I had to replace some of the push in clips cause they were old and broke. Other than that take your time!
Perfect thanks. This is exactly the sort of info I was looking for. And yes, I believe mine is the hard foam type...not the flexible/fabric one in the '94s.
Don't know if you've attempted this yet but it is very straightforward. An extra set of hands will help you remove it from the truck so you don't allow it to bend/break.
Remove both dome lights, rear view mirror, visors, sunroof electrical controls and all the grab handles. You'll also have to remove the trim around the sunroof itself and the doors which help hold the headliner in place. Remove the "B" and "C" post trim also.
At this point, it will be supported by the circular "push in" type clips and also the trim on the "A" pillars. When I did mine, I popped out the top support clip on the "A" pillar trim just prior to removing the headliner. By popping it out, the trim will still support the front of the headliner (which is the weakest) but you'll have plenty of room to maneuver it around for removal.
Go collect a friend then remove the circular "push in" clips. At this point, you can remove the headliner by tipping it on it's side a bit and carrying it out the back of the truck.
I actually prefer to remove the plastic pins first and leave the sunroof trim in and rear hatch edge trim in to hold it in place. Then one person pulls the sunroof trim and the other pulls the rear hatch trim. They are way easier to remove while supporting the headliner than the plastic pins are which require two flat head screwdrivers on each side to pop them out or a trim removal too.
I did a video this week of the removal process for the person who is buying my sunroof as I part out my Cruiser and I just might post it on youtube as one of my last contributions to the 80 series section. It's not too embarrassing and only about 50 Ummmms in the video.
I don't remember any difficulties in removing it. I do remember, however, spending an inordinate amount of time placing supports underneath at various locations to ensure it would not break when lowering it. This driven by the astronomical figures quoted for a replacement.
I used some clamps in the back windows the first time when I was installing the rear cargo light. But this time I just left the rear hatch trim and the trim ring around the sunroof in place and it held fine.
