I have a '91 FJ80 3FE that has trouble starting; mostly in the morning.
I turn the key and maybe get one-two cranks. I'll turn the key again and get no cranking or maybe a couple more. A few key turns after this will result in zero cranking. If I keep turning the key with a couple ten counts in between it struggles to turn over and then finally starts up (It sounds terrible when it finally does start but that goes away after a few seconds - lots of vibration etc.).
If I turn the truck off after it having started; it will fire up. At the end of my 9 hour work day I usually have no problem getting it to start. Some days the problem is worse in the morning and others its not too bad. The problem seems exacerbated when the outside temps drop below we'll say 60F (but this could be red herring).
I've applied power directly to the starter and it sounds just fine. If I turn the key rapidly from ON to Start it sometimes helps but not always (this might also be a red herring).
After pouring through every thread I can pull up in search, I'm still not certain as to what the issue is.
