91 failed smog. High HC
fresno ca
I just acquired this truck that had been sitting 7+ years. I fixed the check engine lights and some damaged intake and vaccum hose. She runs a lot better but idles low at only 500-600 rpm when warmed up. Any help on what to check or replace will be greatly appreciated.
Holy crap there is a lot of 02 left over there...Make sure the engine is not misfiring. First thing is to check your plugs and wires. Then look for and fix any exhaust leaks. You might also be looking at new cats. If the last one is the case you will want to replace the 02's at the same time.
Gross polluter?! Oh on... wait... that's Fresno, SJ valley air is already bad. Carry on.
"Quick smog and cigarettes"...?
GP is not good. A good idea to do a trial run before actually going through the recorded one with iffy trucks. Water under the bridge now.
Excessive HC suggests questionable cats maybe?
Clean your throttle body really well, then clean your EGR out/test it, get hotter burning plugs and check your cap, rotor and replace your plug wires. Pull your injectors and have them cleaned and balanced, if it sat for a long time chances are they're not running right, replace O2 sensors. Replace your fuel filters and test your smog/air pump. Remove and clean the idle air injection control valve and test your vacuum canister.
spray down the maf w/ the appropriate cleaner. I'd replace cap, rotor, wires and spark plugs. Clean TB as mentioned above, I like to remove and clean the EGR clogged port. I assume no OBD2, but I'd replace the o2 sensors as well. After that, It's time for the more difficult things - fuel filter, exhaust work, etc.
Thanks for all the replies. The damn radiator started leaking today so I'm going to go through and replace all the cooling components and the hoses I haven't already replaced. I might just put it in the garage for now and start a another 80 build thread. :meh:
I should have removed the radiator but instead I removed the running boards and stared at her until it got dark
HC is only way high at idle. Everything else passes. This suggests a lean misfire at idle, which may be due to a vacuum leak after the MAF sensor or after the throttle plate or a bad MAF sensor. Other possibilities are less likely. Are you sure there are no CEL codes? A misfire should set one.
How long will a code take to come back up after it's been cleared by pulling the fuse. I hade the code 24 but I changed out the afm and cleared the code.
so replaced the leaking radiator today. it took way longer than i expected. drove it around for a while and sure enough the CEL light came on.
i have code 25 and 26. rich and lean at the same time? i don't have the fsm. ill be replacing the O2 sensors soon. anything els i should do?
what's all that about there being only a problem at idle? HC is also way above max at high rpm if I read this right...
It is all relative:
It is 10-fold higher than the limit at idle and it is only 0.5 fold high at 2,400 RPM. I think that if your problem goes away at idle it will be OK at speed too. Things like an O2 sensor don't generally work worse at idle while the MAF can have a big problem at low air flow.
More likely a MAF or air leak problem than O2 sensor because it is only a problem at idle. Could also be a fuel pressure or injector problem.
Well there ain't no maf on this only a air flow meter. It was replaced last week. That's fixed the code 24. Next weekend I'm going to drop the tank and go through the entire fuel system starting at the tank. The truck did sit for a decade with a 1/4 tank of fuel.
My bad. If the afm checks out fine with a ohm meter and all the numbers are within spec could it still be faulty
Does it run rough at idle? This would be consistent with a misfire. It not, it may be a stuck/bad/burned/misadjusted exhaust valve letting fuel leak into the exhaust. It is such a large amount of HC it has to be something dramatic.
