I think I just ordered one.I saw that post before. That is the reason I asked how many such clip you have on your cover.
Thank you.With the help of CruiserDan I have compiled a list of the parts you'll need for a 90k service:
16100-59275-83 - Water pump (complete assembly including gasket)
13568-09070 - Timing belt
90916-02586 - Serpentine belt
90915-YZZD3 - Oil filter
90916-03100 - Thermostat
16346-50010 - Thermostat gasket
17801-50040 - Air filter
The YZZD3 oil filter is what your dealer will supply. There is a better and larger filter available, the JDM spec 20004. It is not stocked in the US parts system but is available from CruiserDan at his dealership.
You can also do the idler pulleys and cam/crank seals at this time, though not required:
13503-0F010 and 13505-0F010 - Idlers
90311-A0001 - Crank seal
90311-38065 - Cam seal (x2)
The iridium plugs don't call for replacement until 120k. I was late doing my timing belt at 105k, so I went ahead and did the plugs also:
90080-91180 - Spark plug (x8)
Remember, you'll need ~8q. of oil also.
At 410,000 miles, I will perform my third 90K TB/WP service on my 03 100. In addition to items listed by Trunk Monky, I always replace the heater tees and fan bracket. How often do you guys replace your fan clutch (Toyota #16210-50050 or AISIN FCT-021) ?
