- Joined
- Jul 22, 2012
- Threads
- 640
- Messages
- 17,693
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
Another note : It’s BEST that it’s a head gasket. That is a lot better then a cracked head or block.
Matt is right...lol THANKYOU. It’s hard, this is my daily driver. I don’t want to be driving anything else but I also can afford the time and money it would take at this time. I have a vision of where I want the landcruiser to be but realistically I know it’s not going to happen right now. Leak in the gas tank? Slapped on some JB Weld. It is what it is and I’m constantly combatting criticism amongst friends and family to get something “reasonable”. I just can’t part with it, I’ve lived out of this truck before. Drives me crazy that I can’t do what’s always best but I try to give myself some grace. I’ll definitely consider liquid head gasket and will probably be reaching out for more questions about it.
Thanks for your reply![]()
You'd better check for a leak in the tranny cooler tube in the bottom of the radiator.UPDATE: heated up again yesterday... although it did drop down.
A.T. Oil temp light is on near the shifter, checked the trans fluid, seems fine but definitely hot as it was reading over fill line on dipstick...
Okay, the A.T. Temp light is on when I start the vehicle. I’ll report back with tempsDo not put liquid head gasket “sealer” garbage in your engine.
Currently your ONLY indicator that it is actually overheating is the temp gauge. They are just a dummy gauge. If there is nothing in the overflow bottle then the system isn’t pressurizing enough to push past the radiator cap.
I’ve overheated cruisers. The caps pop and hiss and dump coolant into the overflow. It usually has to get to +245 degrees to do that. I have a digital gauge so have actually verified that.
Next time the temp gauge is climbing, have an IR gun (they are cheap at harbor freight). Ready and put it on the radiator hoses, radiator, cylinder head, thermostat housing. Report back here
The next real diagnostic step is a coolant pressure test. With all the spark plugs removed, and compression tester handy at the same time.
I chased this one when baselining my 62, turned out to be the transmission "computer" that controls that dummy light down in the passenger footwell. However only replaced that after cleaning out the trans filter and replacing the trans pan gasket, replacing the AT light sensor, installing an external trans cooler, doing a Rodney flush, and replacing the neutral safety switch didn't clear up the light. Hasn't come back on since.Okay, the A.T. Temp light is on when I start the vehicle. I’ll report back with temps
Well it’s been a month and we are eagerly awaiting further information! Primarily cuz my coolant is going down as well and I smell coolant and can’t for the life of me figure where it’s going.
this is the one i used, like $15
Did you get mad and sell the truck?! Found my leak and bet $100 yours is the same. I pressure tested the cooling system w dye in the radiator. No pressure loss over 30 min. Started it up and this is what I got out back. Gotta be the head gasket. See pic. On another note, I also have a no start (CEL won’t come on when I turn the key to give me an ok to start condition). I jumper the two thicker wires in the EFI MAIN RELAY by the passenger wheel well under the hood. Gotta remove it when I stop or it runs the battery down. Still gotta chase it down. I’ve heard of an under the hood wiring problem that can cause this.Okay, the A.T. Temp light is on when I start the vehicle. I’ll report back with temps
