MOTOR AND PUMP ASSY, WINDSHIELD WASHER 8531012130
85310-12130 alternate part #. CDan was about $50.
Ordered. Old one lasted 20+ years, hopefully new one lasts as long or longer. Also got a new rubber grommet for a buck more while i was at it.
thx spook! twice the cost but should be an easy swap - didn't like seeing the splice connectors on the ones i found @ Amazon.
Hate to hijack but has anyone one found a replacement nozzle that sprays as opposed to shooting a stream of p**s at the windshield?
A friend of mine put some nozzles from a Tacoma on his 94 mini-truck. He gets a nice fan spray. I'll ask what he had to do to make it work. I'd also like more coverage from the spray.
They'll only squirt with the headlights on by the way
Butt
Double D'oh
I misread the OP as "Headlight" squirters
Butt
Glad you got the headlight squirts sorted..... decide to fill up the reservoir and see these headlight squirters do there thang, since they have never worked this whole time, while thinking why in the heck do my HEADLIGHT squirters work now all of a sudden, and now my WINDSHIELD squirters NOT work, but from the same button that used to do my WINDSHIELD squirters?!
WHAT HAS HAPPENED?
YES I AM!;pOOPS! I just re-read your reply to your original reply.
so the first part of my reply to your reply does not apply..
(confused yet?)
That's EXACTLY why somebody turned those around!By the way, these HEADLIGHT squirters shoot out away from the headlights about 15 to 20 feet in front of the truck!!! this would only be useful for playing a sick joke on one of your friends by pulling up to them while they are standing there and start squirting at them with the headlight water cannon.
thanks for your help guys, got the Taap wiper fluid pump today from Autozone and put it in, cleaned the nozzles real quick with a safety pin, and boom! Those things squirt far! almost go up and over the windshield.... haha
It was a burned out Toyota windshield wiper fluid pump after all.
appreciate the responses for help!
aloha,
/s
Are you saying the windshield washer should only function with the headlights on? Do I need to have the headlight washers hooked up as well in order to make the system work?They'll only squirt with the headlights on by the way
Butt
ButtAre you saying the windshield washer should only function with the headlights on? Do I need to have the headlight washers hooked up as well in order to make the system work?
Found it with another search! Yes, a check valve. found on Fleebay, Toyota OEM part number 85031-30020. Ain't cheap!My headlight washer reservoir is cracked; is this why the fluid drains out the headlight nozzles or is there a missing spring valve supposed to be in there.
Echo the headlight spray "cannons" There is a lot of fluid that comes out of them!![]()
Yah had the same issue, easily adjustable though, they can be removed and adjusted (bending or just how position when tighting) made a huge difference was making all the cars behind me angry before this change ....Mine are ancient and I have to be going at highway speeds in order for them to even squirt the windshield.... usually they just fire straight up over the truck![]()
