82 toyota PU, manual box
vht
Brooksville Ky
New here and need some help. I have a 82 toyota pick up, SR5 I was told, manual steering gear box that I need parts for. I could use a pitman arm, the box is a 2wd but a dropped one would be better. Also I could use a lower seal, they tore it up removing the pitman arm, and a steering joint to attach the steering column. I think mines a 36 spline but counting them is a pain. I don't care if they are used if a member has them, I've searched the net and everywhere and can't come up with anything, Thanks.
Wrong forum...wrong place to look for parts also.
Try the truck board
95-older Toyota Truck Tech
There is someone on there doing an 82 project as I write this.
Look in classifieds for parts.
If all else fails you could look up parts on www.toyotapartsoverstock.com
If they don't have the parts you can at least find part numbers to google.
