80 Series Superchargers Availability
Nevada
Looking into getting one for the 80. Are they still available and if so what brand sells them?
Believe they're all made by Magnuson. Was able to find one last year(with help here) but I'm not sure if they're in production any more(there was talk about another run, but I haven't heard if it actually happened). Found mine at Sparks Toyota. 4+ Gs. One of the best mods to date. Good luck.
Watch the classifieds. About the best bet.
This ^, but you better watch closely as they go fast and for $$$
And I'm not joking when I say this: you're probably better off looking for a rig with one already installed, removing and then selling the 80.
Good luck man.
  • Like
Reactions: RFB
A little birdie said that Magnussen is aware of the turbo build.
Does that mean they may run your setup or produce another run of SC or just nothing??
5 psi boost is same as TRD setup. Barely noticeable at low rpm because ECM pulls mucho timing back til you get over 2500 rpm. I am running 8 pounds of boost, still not a lot. It makes no difference at low rpm for towing. As usual, their performance claims are over generous. No need for extra injectors on OBD II rigs, and OBD I rigs require a piggie back.
I have access to one new in box. $6500. PM me.
Well.
You'll be sleeping WELL.
Superman does good.
