Those 94 cloth seats are the most comfortable seats in a 80-cruiser period. And it not only gives you more leg room, but they sit lower as well.
Sounds like something I will completely avoid!
- Mark
wngrog said:Do they fit in the same 4 bolt holes as the electric seats?
NOW its an 80 section
Leather vs cloth ..serious stuff there ; )
wct49 said:Damn right!
Ok, serious tech. Michaela's 80 is having a brake problem that has my guys stumped.
Nolen was driving it the other day and noticed it and i have several times as well.
In normal stopping you have a good pedal, but in panic stopping you apply the brakes and the pedal just stiffen ups like normal but it continues to roll. Its like the abs is not engaging right. No lights, bleed brakes and had very little air out of right rear. But pedal acts normal in regular stopping. Strange...
Is there a way to test the booster? Maybe at hard stops loosing pressure
wct49 said:booster gonna give you a hard pedal, stupid hard when failing, right?
Did you bleed LSPV too?
Probably ABS or master
Either way its nolan's fault..
Vacuum lines look good. Boys in shop are leaning toward a weak booster.
Damn right!
