Made a spot and started working on the front this afternoon after church.
Found the wheel bearings to be rather loose I fear, had a good bit of play in both tires. Good thing I got 3
@beno boxes full of front end parts laying around, but that will be another day.
Dang these things are all beef! Heavy as
Started on the passenger side. Odd, but I've used the original bottle Jack from the 40 more lately then my floorjack.
I had planned to do one side at a time, but the amount rotation needed to bolt these arms meant both sides needed to be dropped. Anyway, I got the DS arm in and got everything tightened up.
Beautiful thing.
The SLEE coils are in along with the arms.
That was where I called it today. I went ahead and put the tires back on and set it back down on all 4's until the next installment.
I didn't get a before measurement, but I figure it picked up a good 3" at least maybe more over the old saggy OME coils.
I still have to get the panhard and shocks bolted up. The parts list gained a few items, mainly I need a longer soft line from the frame to axle and I am going to see if there are any hard lines for the front axle still in the system available for order. Next order will be rebuilding the knuckles and installing the golden hubs. Then onto the rear suspension and t-case swap. I got the fancy front driveshaft, but I will have to test fit and have it adjusted as needed since it's going into a 91.
Overall pleased, but found lots of TLC items that will need addressing over the next few months to get it back up to snuff. Just what happens after 2-3 years of borderline neglect, but that should all be behind me now.
#theraisinliveson
