I'll say it louder for those in the back:
"If the distributor pick up coils or the ignition coil or the igniter were an issue, there would be no/weak spark.
You would also be getting error codes (12, 13, or 14). You said you were getting good strong spark and no codes. Move on."
Spark is developed from the distributor pick up coils which are fed to the ECU and are retimed according to sensor inputs.
The ECU then feeds pulses to the igniter.
The igniter feeds the primary of the ignition coil.
The ignition coil secondary feeds the distributor rotor.
Everything mentioned above MUST BE WORKING to develop spark. MOVE ON.
At this point you have spark, fuel and compression. This engine should run.
********At any point did you remove the distributor********
I'd lay odds that your ignition timing is 180 out.
