- Thread starter
- #21
Thx, just printed out page for bypassing pin fp and b+ from your webpage, will try!..... FYI I own an low voltage av company in Buffalo NY. Thx again Jon, Ill get it. Its just a tractor with efi.The COR gets an ignition hot +12 on pin 2 which also hits the second coil.
Pin 4 is the ground path of the second coil that runs to the switch in the AFM.
When the flap opens, the switch completes the ground path and the COR fires the fuel pump.
On a related issue, have you bypassed all FP logic by shorting pins 1 (FP)-8 (B+) in the diagnostic connector on the firewall?
That should fire the FP with the key in the ON position, bypassing the COR and associated logic.
