$80/liter transfer case oil
Thanks 00279-DGOLF worked 🤙🤙🤙 2 quarts are on the way, $47 each
Unicorn 🦄 tears might arrive
To clarify, the old metal can stuff is now discontinued and will indeed be incredibly hard to find anywhere.
The new plastic bottle DGOLF fluid is attainable and much more affordable.
On this episode of hoarders…
Last time I bought some of the metal can stuff it was already in short supply. If I had known what I know now I would have made a larger order.
Many lubrication base stocks are in short supply due to the Iranian conflict. Producing a low-volume niche product like Toyota "liquid gold" is probably very, very low on the priority list for base stock and specialty lubricant producers right now.
It will probably take years for specialty refining capacity to be re-established (and hopefully on-shored a bit more in the US), so I'd suggest finding an alternate lubricant now with the expectation that Toyota LG won't be available for the foreseeable future.
This may be heresy but I don't think you guys would notice the difference between Toyota LG and a $10/quart 80W-90 conventional GL-4 fluid.
The metal can stuff was discontinued Q4 2025. It was replaced by 00279-DGOLF which is made by ENEOS USA according to the label.
We have CAFE fuel economy regulations to thank for many things, like 0W20 oil and auto start/stop buttons.
I suspect 75W only exists for a marginal fuel economy improvement over 75W90. If Toyota can save 0.1 mpg on every truck/SUV running LG, that makes their CAFE rating go up. I also suspect that Toyota never cared much about the availability of the LG fluid for actual owners, after all the EPA fuel economy rating that CAFE is based is probably established based on the as-delivered vehicle. If the factory TC fill is LG and it gets 0.1 mpg better in the EPA test, that may have been the end goal of LG fluid. If Toyota cared what the 2nd TC fill after the LG is, they would promote their own lubricants (pre- and post-Iranian conflict) through their dealers and make them widely available for purchase. But they have not done that. Again, lots of speculation on my part, but Toyota shares little info so we are left to speculate :).
Luckily my GX470 specs GL5 75W90 for it's Torsen center diff, so that is what I run.
didn't some of the speculation get put to rest here..
It is weird that the phosphorous levels on the Toyota LF is so high. Phosphorous is one of the chemicals (the other is sulphur) that have an adverse reaction with yellow metals. Looks like the LF uses a ZDDP additive package. There are for's and against's ZDDP, but that another rabbit hole. Just looking at composition is a starting point, but running each type for 5000 miles, then sending it out for testing results would have provided a lot more data to compare.
High phos is not unusual for a high pressure gear oil. That along with zinc (combined ZDDP) is the anti were additive package. The magnesium is a metallic soap as Redline uses calcium as a soap to hold the oil as if a grease. Magnesium offers better anti corrosion benefits a temp tolerance and does not interact with ZDDP's. Calcium are more water tolerant and offer greater friction control. I would use Toyo LF 1st choice in transfer case with etc Redline MT-LV 70W/75W as a backup. Currently I have RL LF in mine but have grabbed the Toyo unicorn tears for my next change. Ravenol 75W MTF is too low in wear additives, I would stay away and all the gear box oils, AWL-TOL, MTL and MT-90 have too high of a viscosity.for the application.
It's certainly a nice additive package, but that does not prove or disprove my speculation :). Nor does it prove (or disprove) that the additives are necessary for supporting longevity of the T-case. Toyota would have to opine on the reason their special fluid exists at all, which we all know they are not going to do. But, my T-case is much less robust than the 200 and Tundra T-cases, is nearly 20 years old has over 200K on it, and lives just fine on a diet of $13/quart Mobil Delvac 75W90 GL-5 that is changed every couple of 2-3 years. So, I will contend that Toyota torsen T-cases are robust and not particularly sensitive to minor variations in fluid type.
The final production may be in the USA, but it's possible the base stock still comes from overseas.
The GL rating is based on the extreme pressure rating. The higher the EP it is rated for the higher the GL rating. The difference between GL-4 and 5 is the zinc and phosphorous additives to attain this rating. 5 has double the amount as 4 does on average. Zinc and phosphorus are great EP additives, except that they react aggressively with copper and bronze.
Yeah, I agree. I switched my 2019 to 5W30 mobile one EP full synthetic over the sprc 0w20 what a joke.
When I'm not out in the '80 series we also have a travel trailer. More for beach camping but the tundra is perfect for that.
My understanding is many dealerships dump GL5 75w90 generic in those transfer cases, but Toyota confirmed there's brass bits the gl5 attacks.
This was a really great thread and the oil analysis was very helpful if I didn't run the L F 75w I'd probably go for the gallon of Redline mt-lv-75 for 90 bucks. No big deal.
I ran Ravenol this last time but will probably switch back to the Toyota stuff after seeing the VOA. It’s a bummer too, Blauparts makes it so easy, they literally sell a kit with all the fluids for the diffs/TC plus an extension tube for the front and will sell you all the correct Toyota washers for a nominal fee.
I am sending out an oil kit to Speed Diagnostics on an upcoming oil change. You can send 2 samples out in 1 kit, so I will send a tcase sample as well with about 25,000 miles using Ravenol. This will tell us if wear metals found are in tolerance or not and really put this to rest.
perfect. i have about 1500 miles on my ravenol so far. I am also planning to send it when I do a change. When is TBD...maybe your sample result will determine that haha..
I am gonna go ahead and grab some toyota fluid on sale.
My heretical liqui-moly is still doing fine in the TC. 🤣
You sir are a LC abuser.
You shall be taken out to the woodshed where you WILL drain that German swill and replace it with MUD approved unicorn tears (aka Toyota brand fluid).
I'm surprised your axle hasn't dropped off already.
Repent, before it's too late
Folks over on the other forums....including GX-owning peasantry like myself....are seemingly much more fine with running cheap fluids in our rigs :). I've done my part in being a bad influence via promoting Maxlife ATF over Toyota WS trans fluid, and then Mobil Delvac over Toyota LG. I do, however, use and support Toyota pink SLLC as it's basically the same price as generic aftermarket fluids :).
I too am curious of the Revenol 75w analysis as i switched to that haha.. hopefully its a good choice since Toyota 75W was quite pricey
I wanted to clarify based on what I'm seeing on the Toyota Parts website.
00279-DGOLF-01 is the 75w GL-4 fluid, that is showing as discontinued product.
00279-DGOLF is the 75w85w GL-5 fluid, that is available- but this is a GL-5 and additive pack not ideal for our brass syncros.
That accurate?
So now the move may be the GL-4 Redline?
I can tell you that I have two bottles I just got from the dealer with part number 00279-DGOLF. It says LF75W. It's not discontinued.
The description on the Toyota part site is wrong.
Part Number: 00279-DGOLF
Description: Diff Gear Oil Lf Gl-5 75w-85 = WRONG.
Oh well. I did my oil change this weekend and was also going to send out with the Ravenol diff oil with +25,000 miles on it for reference. When I opened the kit, there was no second bottle like I thought and it also says they don't take transmission or gear oil anyway.
No harm though, I will send it out to Blackstone. Just not with this sample I just sent. It will do it soon, I have 2 new bottles of Ravenol on my shelf that I bought to replace the old stuff with. I just need to get a durable sample bottle to send out. Sorry for the delay.
Confirming, you are spot on- I just picked mine up from the dealer.
Hoping in the next week or two I'll swap the fluids- I have ~30k on my center diff using Ravenol... I'll send out a sample to Blackstone for fun. I'm sure it will look terrible!
