'78 OEM accelerator linkage
NorCal
Anyone know where #60, the torque rod bracket attaches? To the firewall somewhere? I've got all the crap in the pic on the left, except for #53, which is $22 at $OR, but I don't have #60. I'm assuming it anchors #51 to the firewall and provides a pivot there.
Replying with a pic of your pristine '78 would be awesome. Aatlas1x?
Memory says firewall is correct. I'll check in the am.
Not a very good pic....
You can see the #60 assembly on the firewall to the left of the brake booster. The firewall has weldnuts that it mounts to. When I purchased item 60 from the dealership it came as a complete assembly ready to bolt in.
I see it. I don't think mine has the 'U' shaped part shown in GetsUThere's picture below. If I see right, Grant's is like mine and the SOR diagram, with a straight rod going all the way to the #60 bracket at the firewall.
I ordered the parts from $OR last night. We'll see what I end up with.
Thanks all,
Ed
Thanks all,
Ed
The actual throttle rod may have changed in your year. I posted a pic of two that I had a while back here. I don't know what that U shape is for. There's nothing I can see that would interfere with it if it was straight.
It sure wraps around that speedo cable in a most coincidental manner. My speedo cable goes over the other side of the booster.
Another tip, on my '74 was that the nylon bushing that comes with door pins is an exact fit onto the carburetor end of the torque rod.
My stock bushing was worn on the carb end, so a little trimming of a spare nylon door bushing gave me a perfect replacement!
Rocky
