For Sale 77' Sand FJ40 with Powersteering OME lift Ambulance Doors $9500
OMF
SLC,UT
77' FJ40 FOR SALE $9,500.00
I've owned it since 08' and it's always passed safety and emissions. Daily drove it for a long period but haven't used it much the past two years. The door seals are tight, however there is rust in passenger door, top around corner windows, light rust on rear doors (still seal well). The tub and floors are solid. Suspension and frame are solid.
The rust staining around the affected area is making it seem worse than it is. The paint would really benefit from buffing.
Original Motor and Trans 89,000 miles
Carburetor has been replaced with a Weber
Emissions control has been removed
Exhaust was just replaced 2 years and 220miles ago with SOR header, muffler and tail pipe.
Passes Emissions and safety yearly
Mostly stock all the way around with a slight OME lift.
Factory powersteering equipped. The stock pump failed and was replaced with newer pump.
Fiberglass hood was installed back in the day.
Disc Brakes
I'm open to offers and would like it to go to a good home that will restore it, I hadn't gotten around to it and doesn't look like I will get that chance.
Located in SLC,UT.
*correction vehicle is not required to pass emissions (non emissions county)*
More pictures...
front end is tight no leaks,
rear tub solid with surface rust
Engine bay
Many many more pictures available
