- Joined
- Dec 24, 2007
- Threads
- 38
- Messages
- 516
- Location
- Charleston S.C.
- Website
- www.lextechautomotivellc.com
- Location
- United States
1976 fj40 with 3b Diesel 4sp. Dune Beige Hard Top.
I've never had the top off.
I've had this vehicle for about 5 years. Bought it from a mud member in Greenville who did the 3b conversion and the Resto work.
106000miles on chassis and do not know the mileage on the powertrain.
Only put 4500 miles on it in 5 years.
Since I've owned it I have cleaned up the wiring under the hood. installed HFS Front bumper with 8276 Warn winch (used once to remove a fence post). New hood latches, new inner door handle bezel, replaced fuel filter, new injector pump primer, valve cover gasket, lifter side plate gasket, front knuckle service all the way down to the front inner axle seals, resurface front rotors, new front pads, rear shoes and 4 new rear wheel cylinders, rotated and balanced tires, Oil and filter changed with Rotella 15w-40, lots of weekends keeping it clean.
Truck stays in storage at all times.
Was just used in a photo shoot for a fellow mud members wedding who was from NY but was wed in Charleston.
All electrical items work, all gauges work.
Cranks immediately whether cold or warm.
Have many photos of inside cabin, under hood and under vehicle.
1 rust spot on top of rh front fender.
1 rust area at rh rear lower area under the barn door.
Small bubble beginning to show at bottom of rh door.
Gear oil leak from the rear of the transfercase
Engine oil leak from the oil feed line to the back of the alternator for the vacuum pump
15k firm
Have approx. 60 to 80 detailed pics that can be e-mailed
email is best way to contact service@lextechautomotivellc.com
15k firm
