South Texas 97
GOLD Star
- Thread starter
- #201
So left the ammeter in circuit, it’s giving strange results, as the white wire is no longer connected to the alternator. But the alternator is showing 14.4-14.5 volts at idle, and while running drops down a bit to 14.2 or so.
Cleaned up the wiring at the coil, and as suspected the igniter was not really in circuit. However I cannot remove it as the base is spot welded to the coil mount. Ordered up a new coil mount with the dropping resistor. I verified that when the starter engages, there is 12v put out on a lug on the starter. This is the Black/yellow wire shown on the diagram above from the starter to the + side of the coil. Ordered up some proper wire color from wirebarn, so the next owner will not be scratching their head, as I was.
Once the wire comes in, will redo that part of the engine harness and remove the alternator/regulator wiring.
Went for a short drive a small embankment near my house to check the 4x4 and low range, as well as the handbrake.
Overall, a good day’s work.
