- Thread starter
- #61
Few more photos of the steering box setup
Nice work friend! Are you going to do anything to the rockers?
No... I am however sleeving the mounting holes with DOM tubing, and using a plate on the two leading bolts (As it was fitted on Scout and is probably over kill after I sleeved the chassis)...
I am thinking that would not be overkill at all...and that the steering box will twist the frame without more re-inforcements.
I'm sure not going to say your wrong either. I am no fabricator. Just passing along what I heard from my fabricator. Though I have seen FJ40 frames twist from power steering, I have not seen it on a 55...
Your building a great pig. I wouldn't go with a 4bt unless you really love the sound on the diesel power plant. (you will hear it) I lov mine. If you do go with the 4bt make sure it has the P pump, you can get more power out of it. I'm running 3.73 gears, and mine runs 80mph at 1200 rpm. That was the reason for the doubles. I wanted to be able to crawl and put it on the road. If you have any questions PM me I can save you alot of F ups.
I love my rockers, I stole the idea from scottryans green pig. I'm loving your progress keep us in the loop myfriend.
