Build 74 FJ40 Resto-mod build
Today's progress included repairing the hacked up wheel well, while shifting the rear axle back (Jeremiah's guys take material from the rear and add it to the front of the opening to maintain the OEM shape and provide a bit more driveshaft length to help the angle).
Sheet metal work is coming along...after she sat without much progress at the last shop and then waiting for my build slot to come, SO glad to see progress!!
Latest problem with the build before it got to Proffitt's has been identified and resolved. The Hooker header's that were on my engine wouldn't work with the slave cylinder for my NV4500, so these ceramic coated ones were swapped in.
Believe evap tubes were removed at the previous shop.
More progress - engine placement corrected, and metal fab to clear the atlas almost completed....
This weeks update: cage and soft top frame are done. Gas tank modified to clear the new transmission hump. Rear suspension is done. Body work also done (except the front fenders - still deciding on OEM fender vs tube like metal tech). Getting pretty close to removing the tub for paint, and still waiting for the replacement front axle from Diamond.
Subtle narrowed and raised OEM fender looks pretty sweet.
I'm leaving the final decision to Jeremiah and Alex (fabrication wizard) once they fab the 3-link front suspension. They're the experts, and so far have NOT suggested/done anything I don't agree with.
K9 Roof Rack arrived and towers fabricated :cool:
Also decided on adding a Baja light bar under the roof rack to take up some of the space between the soft top and the rack.
Body shop guys had a spot, so she's torn back down and off for the spray liner (bottom of tub and interior) and paint. Going back to the original Rustic Green :bounce:
This is making me jealous
Once done, she’ll be just over the hill from you…going to have to come over for coffee and drool a bit :rofl:
This thing is going to be super smooth! All the yellow stuff is filler, or is it a sandable primer?
Skim coat of filler....just like ALL the top shops do :cool:
