Build 74 FJ40 Resto-mod build
Why do you need an aftermarket accessory drive?
Engine wasn't ordered with one...so water pump, PS mount, AC mount (if mounting a York - no AC planned for the truck), alt, etc....
I mean, is there a problem with all the OEM GM parts? They’re all readily available for both the car or truck setups and then you wouldn’t have any custom parts. I’m sure your shop informed you of this so I was curious what the reasoning was
Shop has had an order with GM Performance for a OEM GM accessory drive that has been back-ordered. Jeremiah asked me if I was ok with the cost increase to go with aftermarket (wanted high output alt, upgraded starter, and possibly a York anyway). Rather keep the project moving along than save a few bucks and continue waiting. Added bonus - the aftermarket kit is a bit narrower, so everything fits better in the SPACIOUS engine compartment 40's have. ;)
Suspension nearing completion. After messing around with the mock up, Jeremiah thinks they've generated enough up-travel that I might need the tube fenders to provide a little extra room. More suspension fabrication porn...
Round 2 of the data plates...just a minor change to the engine compartment plate and I'll have a perfect replacement for my resto-mod
Accessory Drive kit arrived, so time to get more of the engine compartment laid out. Steering shaft, brake booster, and brake lines...
Tub is back to the body shop for final sanding and surface prep before heading to Line-X for interior and underside treatment.
Final sanding and body prep almost done...going to look like a polished paint finish when they get done
Due to some emergency work in the shop, not much happened with my truck the past month. However...fenders looking pretty good all of the sudden ;)
Minor re-shaping of the aprons to fit the tube fenders....also decided on folded steel running boards/sliders which will be look factory-ish when done.
Yea - not something that'll crumple when I run the Rubicon. These will be welded to the frame and powder coated when the frame gets it. Then the body colored line-x will be sprayed on top for traction:cool:
The rush to get vehicles ready for Cruise Moab is done, and my truck is getting worked on again. Current reel on FB and IG showing a battery tray being fabricated is my truck :cool: Also got the air intake, radiator supports, and front bumper in the works...more to follow.
Not sure about the bumper...thinking something closer to a chopped OEM look with insert lights and the winch plate (adding a 8274)
More layout/placement in my engine compartment and just got billed for my paint deposit...gotta love the progress!
