71FJ40 Chevota
Grinder and paint makes me the welder I ain’t......
looks good just a thought I would put a heat shield under that battery, batteries hate heat and extreme cold.. just something simple on the header.. fender well headers look cool but give off a lot of heat..
Good points RayJon.
Also speaking of paint, got a few coats on and then started reassembly.
I’m not happy with the power steering lines so I’m ordering some -6AN
Got the new power steering lines in.
I couldn’t quite get the 37deg die clamped for the tube nut on the return line so I used a small socket and ball joint separator.
Started on the rear end work. Pulled the leaf springs and started stripping them with a wire wheel.
Thinking about removing the smallest leaf.
I flipped the rear springs and so am flipping the MIL wrap. Re drilled the springs, went well with a carbide masonry bit and the drill press. I couldn’t get it when drilling by hand, needed the drill press.
Drill press a must for me too. I got away with a good drill bit and the press didn’t bother with the masonry bit. Cool
Rear diff reinstalled, and new cover finally on
I got this cover from ruff stuff a few years ago and finally got it installed. Happy I snagged it when I did as I think they are NLA
Bolted on @Poser rear disk brake kit, probably the easiest project so far.
Brackets torqued at 45ft-lbs, calipers at 35
I swapped the left and right caliper so I could place them forward and keep the bleeders up. I looked at placing them rearward to keep the brake line behind the axle, but then the line would be below the axle. I’ll try them this way as the brake line will be above and fwd of the low point on the axle.
Rear diff cover looks upside-down. How do you gauge proper oil level with the plug that high?
The rear is rotated up so the fill plug needed to be higher. I intend to fill it with the factory volume of fluid (2.6qts I think) and see where it is with a rod or wire.
The rear SF may be more fluid so it can reach the wheel bearings so I’ll have to double check the capacity.
anyway that was the plan
Had to go to SOR for the rebuild kit for the factory ebrake. Still need to sort out a handle, probably a lokar floor mounted handbrake on the trans tunnel
