- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,500
The Koito kit is a great deal and way better than the sealed beams, however it still cannot compare with LED lights.
However, if you are planning on getting LED’s I would still get the Koito kit because it comes with a relay and cables that increase the amps delivered to your bulbs, which is a good thing no matter what bulbs you end up running.
I like his kit and it is a consideration! I wish he had a less white light option like the Holley/morimoto design.
When is it scheduled to arrive? Or more importantly, will you have it installed by next weekend’s 70 Series event so I can check it out?
Kind of amazing...
I also really like the holleys... the curse of 24V
I did the
STEDI 7 INCH CARBON BLACK LED HEADLIGHT PAIR (FOR LANDCRUISER) they work native 24V
I'm really happy with them, great light and yes they look a little robot but not nearly as bad as some. it's not a bad place and the light output is wayyy better than the old halogens. You don't have to hook up the little 1/2 halo feature if you don't want. You will need to setup to fix the negative switching. But that is true for most 7" rounds.
Build - 1997 HZJ77HV-PEU Build (Grey Poupon)
forum.ih8mud.com
- my original pipe dream and vision is alive and even better now that i ponnied up for HYBRID 12V / 24V compatable 8000K LED diodes bulbs , same shock proof and water proof features ,
- i have been hand assembling each kit from day 1 long before 2019 era of the parts store , you cannont find a better PURE JIS glass lummes LED Kustom Koito LED kit anywhere else on the global market today ....
12V & 24V KUSTOM KOITo LED H4 Headlight Headlamp Kit JDM ( NON-USA) TOYOTA OEM Parts Semi Sealed Beam Sub , W/ Harness Kit w/ Factory Instructions Manual FJ40 FJ55 FJ60 BJ42 BJ44 BJ70 - VintageTEqParts.com
. Our KIOTo KUSTOM LED Headlamps Headlights Kit covers Both 24v Volts and...
vintageteqparts.com
LOW
HIGH
