69FJ40 brake lines
I bought a couple long brake lines from Napa last year with fittings that fit right into my vacuum line. This year I'm replacing my rear brake lines. Does anyone know if Napa sells varying lengths of the Japanese lines? Talking to them doesn't yield many results when your tallking about an antique auto.
What other options? Bubble flare kit? From who?
Where can I get some of the fittings?
I did a search and only got a couple results from searching "brake line supplier"
Thanks
Did a different search through archives and found that the brake lines are not bubble flare but DOUBLE flare. I know there's a difference. The archives revealed that the lines are 3/16 with 10mmx1.00 fittings that require an 11mm wrench instead of the OEM 10mm wrench. Suppossedly Napa has a lot of these? Anyone have any part numbers for varying lengths of this stuff at NAPA?
Not sure about 69, but for my 71 just went to Advanced Auto and bought the metric lines which were about the same length as I needed. They worked great and were cheap to. I think 10mm but not sure, just take your old one or even the connector for the line and see if they screw in.
My '69 had 9mm fittings, you'll either have to reuse your old fitting or update everything else to 10mm
And my 11/1968 fj55 had 10mm fitting. 1969 was a mix and match year for the 9 and 10mm fittings. If you ask for japanese brake line at napa, it will be double flared, 10mm, like most cruisers have. If you need 9mm, then time to reflare or just replace all the hard lines for s***s and giggles.
That must be the problem. I just came from Napa where I bought a bunch of the Japanese lines, then in the parking lot I tried to screw on one of the fittings and the line fitting are too bib. I must need the 9mm. If I replace all the hardlines with 10mm what do I do about all the fittings that are for 9mm? Not sure what I should do. Does anyone beside Spector sell the 9mm double flare fittings?
Can I drill out my 9mm fittings and turn them into 10mm without ruining them? What have other people done to convert to 10mm when all the fittigns are 9mm? Can I buy new FJ40 fittings that are 10mm and use them? What year did they start using the 10mm instead of the 9mm? Sorry for so many questions, I'm dying to get my pig topless and on the road!
I don't understand your problem. Is it that you are trying to find new fittings that
screw into your existing wheel and master cylinders OR is it that you cannot find
brake lines of the proper outer diameter to work with your existing 9 mm fittings?
AFAIK, you will not find the 9 mm fittings anywhere. I have heard that it is relatively
easy to get brake line stock to fit with your existing 9 mm fittings and to flare your
own ends to make new lines. Not much help I know ....
Doubtful you can drill and tap the wheel cylinders and not ruin them. Options include reusing the fittings from your old lines. Verify they are in good enough shape to do so, most common is the flared end gets bulged out and is hard on the threads as you remove/install them. If you do this, you can use any 3/16" brake line.
SOR may still have the oem replacements, I went that route on my rear axle way back when. Not the cheapeast out of pocket, but surely the easiest.
Find some good used fittings from someone here, I bought a dozen from Danny Warden a few years back. Then picked up line and mde what I needed.
You will have to double flare the lines, cheapo flare tools are readily available, and are a pain in the ass, most barely hold/clamp the line tightly. A vise is very helpful to hold the clamp end in place while you work and apply additional force to the clamp. Better tools are available from Snap On, Mac etc..
Or you can upgrade the wheel cylinders, t's and masters to 10mm x 1mm and use the new fittings/lines from most parts houses. The ones sold in the US are NOT Japanese, but European Metric Standard. The thread size and pitch are the same, but the fasterner heads, wrench size is different. They have a greenish tint to the fittings, where the SAE ones are brass colored.
BTW, there are no adapters (9mm) to make this painless, nor can you adapt to AN fittings and braided -3 hoses.
A sketch is worth a thousand words
Here's what I'm up against. I have lots of fitting 'A' but the female thread size is 9mm. I can't find a double (or single flare) 3/16" brake line with a 9mm fitting. I don't mind switching to 10mm, but does that mean I need all new fitting 'A' pieces? OR, can I tap them out and turn them into female 10mm? Is that clearer?
So I can upgarde fitting 'A' to 10mm? I just bought $100 worth of new rear cyclinders. Will that other bolt fitting with brake fluid hole still fit through fitting 'A' to screw into back of cylinder?
There are lots of folks who have gone 4 wheel disc and have thrown all
the 9 mm stuff you need away. I have only a few spare parts for my
'68 and can't help here. I would learn to flare the lines and reuse all
three of the fittings you show in your (nicely done) sketch. I would
imagine that SOR, cruiserparts.net, cruiseroutfitters, marksoffroad
or somebody has a whole box full of those 9 mm parts.
Ya, my 69 had 9mm on the brakes and clutch, and 10mm on the vacuum shift.
Send a private message to bustanutley and to aalien. Both of these
gentlemen have recently done conversions from the 9 mm systems to
4w discs and may have the parts you need. I was going to get the
stuff that aalien has but it was just going to go into storage and it
sounds like you need it right now.
