Looking for brake line supplier
I want to put all new brake lines on my '65 FJ-40 and I am looking for a good supplier. I would like to find a supplier that sells the fittings, buy the correct flaring and bending tools, and purchase brake line in bulk. Anybody know of a source out there? Thanks.
My local Carquest and Napa sell 3/16 line by the 25' roll, $28 no fittings. 60" lengths run about $5.00 with two fittings.
Bernie, what brakes do you have? If they are the stockers, you need to hang on to the fittings you have, or get some of my old ones. Buy the 60" NAPA lines like Aalien said, get yourself a good quality double flare tool, reuse your old fittings and you'll be good to go. The double flare can have a learning curve to it, but the flare is the same, SAE/Metric. I find it much easier to start with straight and bend than to start with a roll. I just redid all mine on a '66, but I have GM rear discs and a '77 LC DB axle up front.
You can do it.
Ed
SOR has rubber lines made up for them with the old original size fittings. Those front short ones in a '65 were $22. the pair and they are a couple of inches longer than OEM. Not sure if they're in the catalogs but calling them to ask about fittings resulted in the guy telling me what they have.
I don't know whether they have all of the lines or not.
Honk, I think even in aftermarket the hoses for a '65 are about $30 each. The flex hoses for a FJ25 are about $22, but then again...each.
I have 2 benders, both pretty cheap. I ruined a measuarable amount of brakeline learning to get it to bend like I wanted it to. It is fairly forgiving, except when you forget to put the fitting on before you flare the end. So I've heard.
GL
Ed
And Bernie, hit me offline if you want any fittings. I even have some decent flex hoses and one facto line from MC to frame. All for the postage.
Thanks for the info. I was going to go with the flaring and bending tools from Eastwood, but wasn't sure on the size of the tubing. I was hoping there was someplace that sold the fittings, but it doesn't sound like it. I can reuse my existing fittings (good thing I kept them), and buy any others I need from SOR. I just started adding up the cost for all of the lines and it was a bit eye-opening.
Bernie
I have a limited supply of new 9mm fittings that I have been using to make up reproduction brake lines for restoration projects. Those 9mm are EXTREMEMLY hard to come by.
Good luck.
might have been each - I just remember being surprised at the low $22. cost. F25? Mine's not, but has 9mm fittings.
A local hydraulic line place tried every source they knew and couldn't find those fittings before I called SOR.
Some import auto parts houses stock straight lengths of brake lines flared with fittings on that you buy and bend as needed, but none that I've seen had fittings like the old Toyota ones.
Anyone knows the correct size brake lines for a 78 FJ40 mine are so rusted out I can't mesure it properly ..... 3/16" maybe ?
Toyo FJ40 said:
Yes it's 3/16 with 10mm fittings
Kevin
Kevin Thank you again, I put some brake fluid in today to see where it was leaking .....it is so bad that as I was pumping on the pedal I could hear it splashing on the floor from all the wheels and one place under the the frame :grinpimp:
I haven't tested them yet but I believe NAPA brake line nuts part # BK6415021 should be the right size
3/16" tube M10-1.0 thread my local napa store didn't have them so I Can't verify but I think this is it....
update
Just checked .. not only they have the fittings but also all the steel lines with the fittings already flared in several lenghts
http://www.napaonline.com/
big time saver as I was going in to buy a roll and flare it myself, they also have the rubber hoses.. :beer: :)
Fittings:
One of the biggest problems with using the premade lines are the unions. I use to work at AZ and we never had the unions to go between two metric fittings. We always had the ones for the SAE fittings, but not metric. With those problems I ended up cutting the line and putting a SAE fitting when joining and reflaring the ends for the metric. Worked fine, but a bit of a pain.
unions
I found a FAQ with some part # for metric unions
http://www.ffcobra.com/FAQ/brakelines.html
and this again at napa they seem to have it all
http://www.napaonline.com/cgi-bin/n...tail.d2w/report?prrfnbr=28621814&prmenbr=5806
also this web site has some info in using brass compression fittings, pretty neat and easy to find in case of emergency
http://volksweb.relitech.com/brakeln.htm
don't know about every state, but NY doesn't allow compression fitting to be on brake lines.
I don't like compression fittings much, I put some in a streetrod a few years ago (and have since replaced them with flared fittings for the owner) and had one heck of a time getting them to seal right, they just seamed to keep seeping. I finally tightened them enough to keep them sealed, but deformed the fittings in the process (with the correct flarenut wrench). A flaring tool isn't that expensive, and you'll have loads better connections. my .02
Bernie, I still have a s***load of the old stuff I took off and you are welcome to it for the postage. Email me and I promise to remember what I offered. That is the old 9mm fittings, lines and some flexies.
Ed
Aalien, those compression fittings should seal without having to deform or ruin anything. Especially if you're using the proper flarenut wrenches. There are some cone shaped copper washers/seals available that will conform to any imperfections in the fitting assembly. I don't know offhand where to get them, but an internet search or NAPA might yield a source for them. I've used them in a shop where it became standard practice to just install them at assembly rather than have to redo the lines when a leak occured. Good Luck
understandable.. but in case of emergency on the trail or anywhere it's good to bring some around
