69 disc brake conversion
I have a '70 FJ40 that I am working on. I purchased the 4 wheel disc brake kit from JT Outfitters and had a local shop install everything. The old lines were ripped out and replaced with custom made lines. I tried a brake line kit from SOR but it was no where near close enough for use. The firewall adaptor from JT pushed the booster out far enough that the master cylinder did touch the Weber air filter so I took that off and installed the Wilwood dual master cylinder from Man-a-Fre without a booster and the brakes are terrific. I believe I have about $2200 in the brake conversion and with how the brakes work now as compared to how they worked before, the result is well worth the cost and effort.
I cut the rib on 64 and made it look like a 72 or newer same firewall disign from what I could tell I just duplicated what it look like and there was no flex at all. Used a 1994 4wd truck booster and proportioning valve and replaced the whole rig worked like a charm on 4 wheel disc. Lot cheaper rout in my opinion
