69 disc brake conversion
Ventura,CA
I know this is probably been asked before. New to the 40 scene. My question is I would like to do a disc conversion. I called a few places I've been told there is no kit for 69 due to the single plunger master cylinder and the smaller brake lines. Anyone have any suggestions or should I stick with drum brakes. Thanks.
IMHO, you should stick with the drum brakes until you can upgrade to a dual circuit system.
I have a 69 as well (drum brakes). Due to the rib on the fire wall you need a duel master adapter that brings the duel master far enough off the firewall that you clear that rib. I forget who makes that adapter but it's readily available.
I've read you might have issues hitting the carb due to the extended master cylinder but don't know from personal experience.
Read mark from mark's off road (on his website) theory on drum vs disc. Interesting read.
http://man-a-fre.com/pa5/tandembrakemastercylinder.htm
I used this from Man-A-Fre and a 78 disk brake axle. Works very well. Not quite the boosted brakes on my other 40's but a huge improvement over the single Master with drums. Remember with the 69 you will have 9mm lines instead of 10mm. This master takes the 10 mm stuff. On my 9/69 (1970 reg.), I used the 78 front and a 74 rear axle to keep get everything to 10 mm.
How hard is to brake without the booster ?
I used Mark's adapter to get me from single reservoir master to dual circuit (mainly for safety). It required bending/flaring some new lines to split from existing single circuit. I did find some 9mm fittings online (can't remember the source offhand but will try to figure it out). I'd recommend replacing any fittings with 10mm where convenient as others have said. Some have run non-power discs, at least in the front. It's seems doable, though it may require trying master cylinders of differing bore size to find what works best. It's on my mind but I've never gotten around to trying it.
its pretty easy to make that adapter. I made one out of a piece of pipe and a small plate. Then just extend your interior push rod. I have a 1968 so I have the same issues as you. if you need any help or pictures let me know. I did the hilux front and the disc brake monte carlo kit in the rear. Check out speedway motors for a proportioning valve they have nice wilwood ones for about 30.
It pretty much feels like it did when it was a single master and drums all around. With the drums, as long a they were adjusted they were fine. I had a soft line split when my son was driving it. He instantly lost all brakes. Thats what made me change to the dual master.
I had the 78 disk axle and the 74 rear drums on parts trucks so i just made the switch. It is definately a harder pedal than with the booster but not bad.
Any idea what the bore is on the Wilwood master?
How did you extend the push rod?
Seen it done. I've always wondered, what's the purpose of the rib? Is there any structural reason for having it?
The rib stiffens the firewall. Years ago I did a conversion where we cut out the rib and found you need to put something back, like a piece of plate steel, or the firewall flexes when pushing the brake and clutch.
I'm setting mine up now on my 68.
60 front discs, Poser rear disc kit and the Man A Fre Dual tandem Wilwood kit. No plans to run a booster.
J
