This is the rig I tried to sell to you knuckleheads six months ago. I had gotten discouraged and ran out of money. Well ... I got excited again and found a little money. The rig now has a 2F engine from a 1987 FJ60. Pre-1968 cars don't required smog checks in Nevada, so I removed all smog gear. I tried to keep the stock p/s pump, but it couldn't find anyone to rebuild it. I went with the Weber carb and HEI distributor for simplicity. 4 speed Trans and T/C from a 1983 FJ60. Axles from a 1977 FJ40. I've never had interest in painting it - no point to it. Whatever paint I put on it will be scraped off by rocks and trees (I plan on running this rig how it was intended to be run). I re-wired it with a 20 circuit standard kit from Kwik Wire. I have NO experience wiring cars - but Kwik Wire is for real ... great price and easy to install. With the 20 circuit kit I have enough fused connections to run more than enough lights/accessories. Quality wire, relays are wired in, instructions are good, and wire is well marked. I cut the steel for the dash cluster and installed Autometer gauges. All sending units went right in without a problem ... only the fuel sending unit is left (I'm working on it). Part of the Kwik Wire harness is a third brake light, so I fab'd up a bracket and put the third brake light above the license plate light. I couldn't find round adhesive reflectors that I liked, so I put on a couple of oval ones. I added 3/4 inch 3-way marker lights right behind the hood latches. I did it as a safety issue - the early FJ40s have NO side lights. I kept the front wire blocks - but got frustrated with the stock ones, so I bought a couple of larger (easier to use) ones. I kept the wire blocks because I really like how they allow you to remove the front of the rig in minutes.
I'm not done, but I finally have it back on the road. Special thanks to everyone for their input and encouragement!! It isn't stock, but I'm trying to keep it real.
***See Below for Pics***
