I raise you an 81 that in the pics is cleaner and has a BIN of under $22k
1981 Toyota FJ Cruiser FJ60survivor runs as good as it looks clean title | eBay
I believe they are OME mediums. I'm running JT Outfitters Extreme shackles as well, so that's why it sits up a little higher than a plain OME kit.Which rear springs do you have?
I just went out and measured it to double check. The driver side rear is 1" higher than the other three corners. I believe this is the same issue @wngrog had when he installed his. Maybe I'll stack up a few bags of quikrete in that corner to level it out![]()
Both were B. Just checked and the + spring is on the passenger side. If I remember correctly the + spring is supposed to be on driver side correct? (and I installed it on the wrong side)Do you have A & B rear springs?
You can chase that lean forever. I would not do anything until you do a good break in period.
Is that yours? I had one like that I sold......
