#6 plug- wet
So. OR
Routine Mx today found the #6 plug wet at the shoulder with brown sludge and a little on #5- all plugs were coated white. Looks like I need to make a decision on that swap or a rebuild/HG job.
How many miles on the engine? How well does it run? Compression test it? Does it use oil? Have you checked oil pressure with a test gauge? How about your MPG? All things that may assist in your decision. These engines are are very durable and worth you time whatever you decide.
203k, It runs well. But as the ambient outside temp increases the performance suffers. No Psi test yet. It burns oil(1qt every 1500m) and smokes on start-blue smoke. oil pressure is good. MPG sux just like yours! 11-13mpg. I have a Blackstone kit that has been sitting on a workbench for 6 months. Given that I have 3 trips planned this summer I really dont have a choice but to pull the head and do the HG and associated work. The temperature runs at 178-181 all the time. Very consistent. At this point I view it as preventative- its going to fail.
I am finishing up my HG now along with a long list of other "while I'm in there" stuff since access is much better with the head off. It's a pain in the butt job so don't get in a hurry.
I was thinking of getting the DVD floating around here for $25. I have the FSM but an over view for cheap would not hurt. I did the Dizzy, water pump, oil pump, and crank shaft seal in December along with all new belts and hoses. I also just put a Koyo 2 row in it. Dorkel, CB and AUssie are all waiting for install LOL.
That plug looks fine. If it's wet/oily at the shoulder it's probably spark plug tube seals.
So, I think its time for me to get off the HG hysteria bus and send my Blackstone in! The tube seal had a sliver/corner missing on #6...BTW. Its hard when you are base lining the maintenance on a 20 year old truck not to want assume the oil burning beast of a tractor motor is going to have a failure. I guess if I equate to my professional experience burning oil and fuel at prescribed rates per operational hour is normal--- :-)
The FSM lists leaky spark plug seals as the number one cause of misfire. When I replaced mine,some time ago, the misfire at idle went away. If you see blue smoke on start up, your valve guides and seals are leaking. That's no big deal especially if your "tractor" motor is running fine. If you decide to do the HG do yourself a favor and spend the money on an OEM gasket set. I first bought a DnJ kit on the advice of a MUD vender. I waisted $200. The HG looked identical to the felpro that came off. The OEM head gasket has the toyota design changes and was obviously more robust and higher quality. Have you inspected/wrapped you wire harness near the EGR tube? Most are heat damaged. Mine also had two bare wires.
my wire harness is not damaged. The truck had been left at grandmas for several years when I bought it. Actually in pretty good condition; just like most on here that were not maintained. I will wait for the Blackstone report. Hopefully the HG paranoia is just that.
What this guy said. If your spark plug is shiny new looking like it was steam cleaned then I'd be worried about a head gasket. That plug looks fine, old and used but perfectly normal. Well, except for the plug tube seal leak ya got.
The plugs look good to me too. The gap looks too big though. The black looks fine for an engine with 203k miles. Your oil consumption could be reduced with something as simple as a PCV valve needing to be replaced.
I would say that as long as the gas mileage is staying where it is, and the engine doesn't ping from carbon build up, let it ride until you have a real problem. Fix the leaking tubes, do a throttle body cleaning, an get on with your summer vacation!
The PCV valve and all hoses are new. Thanks to those who chimed in- much appreciated!!!!
