Good fuel economy lol...
This is simply a case of both sides being correct.
my head hurts reading acronyms, abbreviations and oil spec listingsJust a guess, but there isnt anything readily available in 0-20, 5-20, or 5-30 that isn’t GF6A.
My bit of research has concluded avoid GF6A and anything over 900ppm zinc and 800ppm phosphorous. MB229.52 is a good starting point if you want to go down the rabbit hole.
I am also swapping out my transmission and transfer case fluids.
I wish I had been using 5w30 in my 18 land cruiser all of these years instead of 0w20 for its first 35K miles.I know it’s a very different engine but this has been discussed endlessly on the LC200 sub forum for years…and I would say a majority of members have switched to 5w30 or higher. The 0w20 is definitely due to US mileage standards, no other reason. Given that the same engines are spec’d with thicker oils everywhere else in the world, I don’t think Toyota would or could deny a warranty claim based on using an oil they spec elsewhere.
I have seen tests online where 0w30 is thinner than 5w30 even when hot. None of these specs are consistent between oils and brands. 5w oils are still plenty thin at startup anywhere that isn’t frigid. I’ve been using 5w30 in my LC200 for awhile now , and my Toyota dealer gladly does the oil changes with Mobil 1 they stock (I guess they don’t keep Toyota branded 5w30?)
I mean, 5w-30 has been fine in my 100 at cold cold temps (below zero), so I reckon you'll be okay.I live in Utah - should I steer clear of 5w-30 and go for 0w-30 due to cold ish temps in the winter? Or is 0-20 degrees F fine for 5Ws?
My 23 IS500 is 5W30.The other day I noticed a large sticker under the hood of the new LC500 that says 5W30. I have no idea if that is what was required in prior years but it is there now.
I find that very interesting, especially since they recommend 0w20 in the 5.7 Land Cruiser.My 23 IS500 is 5W30.
