5W-30 motor oil
5k on 5w30 for me; about to do my second oil change and staying with 5w30.
Mobile 1 5w-30 has quite a bit higher viscosity and a decently good additive package.
Here is the Pennzoil:
Personally I would run the 0w-30 esp euro mobile 1. 5w-30 mobile 1 if I was worried about warranty.
If I was worried about warranty and wanted to be slick I would run mobile1 0w-20 5 quarts and mix 2.7 of a heavier mobile 1 in. Requires a lot of DIY.
As far as how its running on 5w-30, it’s smoother still. Put about 900 so miles on if I IIRC. Been driving my f250 a lot as i have been moving my skidsteer around. Could be a fluke that I hit 14k miles as i changed it and that was a magic number that day where the engine broke in.
But I do think its sensitive on viscosity. I can pull it out of my climate controlled garage and later in the day feel a difference as the temps climb up to the high 90s. It started getting hot here in the last couple months.
I have pretty extensive background around heavy machinery and manufacturing. Owner and operator. Watched my dad be able to put his hand on a CNC machine and know when it was ready to be taken out of service or moved into lower precision machining etc. Blah blah blah.
I may be crazy but I think all the fluids in these, besides the diffs, are extra thin for MPG cool-aide drinkers. The tuning is also horrible.
Yesterday, I took my 24 LX600 in for its 35K oil change and had them use 5W-30W Amzoil that I provided, along with an Amzoil filter. I also had them take a sample of my old oil with 5K miles on it (5w-20w) so I could send it to Blackstone for analysis. They did not say anything about me using 5W-30W. I was a bit surprised that my oil pressure didn't seem to increase with the new oil.
It will be interesting to see if my mpg decreases.
Edit: I just got back from about a 250 mile trip on I-35 with the 5w-30w and according to the car's MPG average, I got 23.6 driving between 75-85. That may be better than I got with the 0w-20.
I just took my 24 LX600 in for its 40K service. I said to use 5w-30w. The tech chastised me in the video he sent of the tire, brakes, etc., saying that 0w-20w was recommended.....I said to use the 5w-30w. I wish I had the spec sheet for the ROW to show him that the valve train will be just fine with 5w30.
I just did my 10k today and switched to 5w/30.
No grief given by anyone at the dealership.
Too few miles to say if it’s an improvement and I really didn’t have vibration to speak of (only ever noticed it in sport s or sport s+)
Just looked at the Austrian tundra hybrid manual. Looks like they only recommend 0w-20. 5w-20 is ok but only for a short time. Makes no sense why the non hybrid would have 5w-30 option but not the same engine in a hybrid. Doesn’t it get crazy hot in AUS????
Austria or Australia? It is much hotter in Australia.
Ha! No i meant Australia. F ing autocorrect.
Yeah I was surprised that they didn’t recommend 5w-30 as at least an option. The manual highlights 0w-20s good performance in cold environments…which is obviously crazy for that continent
I may be wrong, but I think the 0w20 "craze" that automakers seem to be on is related to gas mileage for the governmental tests and not long term reliability. I only wish I had been using 5w30 since day one. I have put 40K plus miles on my 24LX in the past year an a half and just started using 5w30 at 35K.
Well, it could be worse. My daughter's '23 Corolla specs 0w-8! Not a typo. Manual says 0w-16 if 0w-8 is not available. Been using the 0w-16, 0w-8 is expensive and impossible to get. I'll be going 5w30 soon. Guess what ROW spec is for the same engine?
0w8. I have never even heard of that. I guess that might be useful in the arctic. My guess ROW for same engine is 5w30.
as Ed McMann used to say to Johnny Carson (RIPx2)...
You ARE CORRECT, Sir. :slap:
5w-30, the golden elixir for all your motoring needs :steer: couple that w/conservative OCI such as 5k miles and you too can have an engine like my LX450 which only has 440k miles and doesn't ever need oil added between changes.
Full disclosure: Rebuilt said engine at 372k miles and wasn't using oil - rebuild was mostly 'cause I like doing that kinda thing🔧:banana:
Can't make this s**t up. Every time a new model or technology comes out, someone thinks an engine made by the Neanderthals in ancient times is better than a modern, fuel efficient, engine.
Bragging that your engine made it to 440k but had to be rebuilt because you just wanted to? Are you trying to undercut your credibility?
In all seriousness, is it possible that all the v6s blowing up could have been avoided by using 5w-30? I know nothing about cars compared to you all but wouldn’t the bearing be less likely to blow up if it had better lubrication?
the ttv6 dilutes the oil more with fuel due to being boosted and larger ring gap so your 0w20 isnt 0w20 pretty quick....
and with 2 less cylinders and the same hp and torque as the old v8 (and twin turbo pushing) now you have more pressure on the bearings..... which would be ok if your oil is ,say, 5w30 or 0w40....
then throw in a giant snafu of some machining debris from not properly flushing the engine blocks during manufacturing and we have a perfect shiitstorm to kill an engine.
Change your oil 3 times before 1500 miles use 5w30 or 0w40, and you're golden
I did...alot of crap came out at the first 500k oil change
I’m sold on the 3 old changes in first 1500 but I’m still mildly concerned that they didnt spec 5w-30 on the Australia tundra hybrid. It’s so weird, the hybrid and non hybrid lx have the exact same engine. I will probably just roll the dice and do 5w-30
do 0w30 if youre worried about it... same cold start / stop and start flow and better hot film strength
i use 0w30 here as it is cold,
5w30 in summer if i cant find 0w30 at a reasonable price 0w40 if towing etc...
its just oil, and most oils overlap viscosity if you read the actual cold/hot thickness anyways, ie amsoil 0w20 is as thick as some other brands 0w30, and some oils get real thin when measured at hot temps vs cold temps.... etc
Totally agree, if you are in the US, and maybe Canada, get the 0-30 mobile 1 european formula from Walmart. That shouldn’t raise too many warranty redflags especially if you live in a warm climate. The cSt @100 is ~12.2 and that is like a low viscosity 40 weight. It maxes out the additive package, without harming the catalytic converters.
I am going to order skid plates when I get back from this hunting trip I am on and then change the oil so i can just do both at once. Side note; bonus this year is I have been in a new Hilux, spent a few hours off roading it and 6 hours on the highway. No exhaust emissions from the factory smells like my deleted powerstokes and the only mods it has is a camper shell and Nokian Outposts. Kinda loaded but still basic, neat little truck.
Oh and here is my oil update. I have like ~3,000 miles on the 5-30 mobile1 GF-6A junk but it has ran substantially better than the 0-20, its crazy. Also the motor holds 9.2 quarts iirc and I only did 7qts no filter. Its a little diluted.
Really really regret waiting till ~6k miles to do the first oil change with 0-20, ~10k 0-20, and then finally at ~13k with the 5-30 mobile. Makes me sick 🤮 . If I knew what I know now I wouldn’t have driven it off the lot without swapping out the 0-20.
Going to run the 0-30 euro and dump a couple quarts of super car 0-40 in it too (what GM is using in their problematic 6.2L motors). But only 2-3 because the additive package can eventually damage the catalyst. Its also not cheap.
I need to get the programmer on it, skids, and auto start stop thing. Too many projects just need to get up early one sunday and do this stuff.
I also have some Redline D6 for the transmission and going to swap the transfercase fluid to a high quality 75w85 or 90.
