I'm starting to do lot of research into putting a 2003-07 LQ4/LQ9 with a 4L80E into my '96 FZJ80. @lazy's thread about his conversion has been a massive help, and I plan on following his footsteps except for a few things to keep my budget down. I plan to run the OEM gauges and radiator, and trying to keep my budget around $7-8k). For instance, for my fueling, I'll be using GFBN plastic bundy fittings with rubber fuel line instead of the fittings and AN lines he ran. I've got a google doc/sheet that I am working on with my build for others to follow as well.
Anyway, I have a few questions that have arisen that I would like input on. I know lazy installed a reluctor ring in his 4WD transmission - What needs the ring to read off of, the GM ECU? I would prefer not to even split the engine/transmission on my purchased donor swap. If I went with something like the Marlin Crawler VSS, I assume this goes where the Toyota speedo was in the transfer case, then how does the speedo get a signal? If I do open up the transmission, is it a big job to get down to that output carrier if I leave everything else alone?
Next question has to do with the Marks adapter... I would assume so, but does it work with the H2FAV that is in my LC (as opposed to the H2FA)?
