40 series general tech and classifieds
I'm looking for a set of 4 steelies compatable with disk brakes. Condition does not matter too much, as long as they are true.
as a person in the business, I can attest to how bad a false wheel is....
2F is headed to 49 Cruisers for inspection for meat neck
Nice! giddy up
I need some 2F luck
So I think maybe there's a problem here...
Pulled driveshaft and opened drum and the xfer case is draining out of it?!?
Is that just the seal between the two? That's a new seal...
PS I hate this damn thing tonight...
Damn, just look at that pretty frame. Drool.
T-case isn't hard to pull if you really need to. Most of the bolts are accessible from outside but 2 (I think) have to be removed inside the long cover plate. Then you need to make a sort of puller to separate it. I think I can find the one I made years ago if you decide to pull it. I would sure try another seal first though.
Can anyone tell me what gauge sheet metal is on a 1978's dash? 18ga?
I'm sure Braswell is too hard headed for this but once Rob determined the guts of this beast is good he should just let Rob do the swap.
Make the FJ40 Great Again
#MFJ40GA
Someone that works at the Chick
Fil A on Poplar by The Belmont
Fine
Rocking 33s 1.5" shackles. Stock springs.
Steelies and caps. Uncut fenders.
Yes yes yes
That's the same color and mods that mine will have when its done.
@wngrog , that's for the heads up about the powdercoater you suggested a few weeks ago; I talked to him today. Sounds like he's gonna be a good fit.
Please help me keep a lookout for a Detroit locker for my rear axle. Thanks
