4" Lift Question
Trenton, NJ
I'll be starting on my 74 FJ40 in the spring. Once the axles and frame are complete I will be installing a 4" lift springs. Question is, will I need to change any steering parts to accomodate the lift? Stan
I agree
I just completed a 4" lift (BDS) and had to recenter the range of steering via the drag link. The other item I needed and or changed was the brake lines. You only need the ones from the frame to the drive lines but I replaced all 4 at about 25.00 (stainless steel) ea. Not cheep but they sure look good. :) The attached pic shows the old line stretched after the 4" lift.
Why wait till spring? Winter is a good time if you have the covered area to work in and can take your time.
Have fun!!
Thanks for the info. I would like to get started now, but between work and studying for a promotional test I won't have time. In the mean time I can accumulate some goodies for the project.
I think that is the prob i am having with my 4" lift. I bought a used skyjack and put it in.. took it for a drive and it was doing a mild hop in the rear. i need to test it again in daylight. my drive shafts might have issues.... might be too old too.....
