So who out there has done any mods on their 3FE? And what was the outcome?
What was the Mod?
How did it perform?
Was it worth it?
What was the Mod?
How did it perform?
Was it worth it?
EGR delete.
I left the O2 sensors in place, but removed the cats.
Runs and idles so much smoother. Slightly more power and fuel economy.
Yes, it was worth it.
I wish we can do that out here in Cali.
mechanic...)I am tempted to send the throttle body out to be bored. IIRC, there was a post on here somewhere recommending a shop that does this for around $300.
For what its worth, I *might* be making a whole bunch of different block off plates from the waste material from another project I'm working on.
to The Man.For what its worth, I *might* be making a whole bunch of different block off plates from the waste material from another project I'm working on.
Only if its anodized red and has the name engraved.to The Man.
OMG! You are going to make 3FE stuff?!?!
It's more of a "while I'm there" kinda thing![]()
@82much, thx for helping get this all cataloged in one spot, sorry not in a mood to include a bunch of hyperlinks, mine:
NOT 3FE mods but notable mentions concerning performance:
- Didn't do full EGR delete, did the 'BB' trick instead. Accomplishes the same without removal of components (easier to go back to stock, still eliminates hot gas recirc). I never found any absolutely positive claims that the smog pump has any significant parasitic drain on engine performance so that's where I landed. YES to noticeably smoothed out idle, maybe a placebo/seat-of-the-pants improvement on throttle input but I wouldn't expect to see anything on a dyno. I'd only put back to stock in the event I sell, it made that big of a difference (again, nothing you'd see on a dyno but a much better engine feel once done).
- AFM 3-clicks - advances the timing. YES to a slight MPG increase and another very small placebo/seat-of-the-pants gain (throttle).
Everything above was totally worth it. She's no rocket ship but MUCH better than when I bought her - starts every time and gets me there-and-back, up every hill I've ever pointed her at. For comparo:
- Full baseline treatment - @jonheld, @SUMMIT CRUISERS, @LS1FJ40 (I'm sure there are others) are all huge contributors - plugs, wires, hoses between AFM and throttle body, fuel diaphragms and dampers (don't go for that "magic screw" nonsense, just replace the part), new vac hoses, fuel filters (2), O2 sensors, etc. Go OEM or bust...
- New exhaust/muffler (y-back) - awesome sound improvement, perhaps a smoother running engine/idle but that one was quite a while ago (more of a "had to do it" replacement than an intentional performance mod). The old threads about a stainless steel option (can't remember name) had some decent HP gain claims but over time as that outfit went out of business, many people were terribly unhappy with the fit/finish as well as customer service so glad I avoided that option. Couldn't tell you that the route I went with would have netted any dyno gains.
- Cleaned throttle body - immediate "smoother idle"/throttle response again, not a dyno improvement.
- Freeway runs - the 4.88's were the best PERFORMANCE improvement, hands down. On flat to mild ascents, this is such a better interstate rig than when I bought it. Steep hills are still steep hills, downshifts are part of the deal.
- Taking my roof rack off DEFINITELY has a seat-of-the-pants improvement. Go figure...
Possible future efforts, TBD but partially relevant to your request:
- Bought it and 8.5-9.0 MPG was the norm, currently 12 MPG after all's said-and-done. Long/flat freeway runs are easily 15-16 mpg (Prius-territory, I know).
- Trips up north for me, the number of times I have to downshift to second gear (every 3FE owner's favorite thing in the frikkin' world to do....) has been cut down by half but.....I still have to do it.
- 0-60 - I'm confident (with ZERO DATA to back it up) that I'm at least 10-15% better than when I bought it. But when 0-60 takes you around 25 seconds, you're still not turning heads. 0-45mph, however, that's really a huge improvement and don't forget freeway improved driving tied to the 4.88's.
Sorry for the long post, just sort of kept-on-typing.....long live the 3FE!
- Advancing the flywheel a couple degrees.
- Cat removal (flange this so I can plug back in if so desired).
- Clean everything possible on the intake side.
- EFI relocation (indirect where performance is concerned but that darn engine bay does get HOT); maybe also all ground wires to be replaced.
- Injectors - can't tell if it's truly worth it but some have had successes (e.g. @SUMMIT CRUISERS Jr )
- Sock fuel filter (I've only done the inline to date).
- Charcoal canister replacement (zero performance gain here but I'm overdue - crazy fuel pressure blowoffs at this point!).
