3FE Manual Swap?
Washington State, USA
So I have a 1991 FJ80 with a 3FE and an auto (obviously cuz it’s USDM), and I’d like to swap it to a manual. I know to use a 3FE H150F transmission, but I’m curious as to what else I need to do to get it ready for the swap. Like, what about the ecu? Would it freak out if I pulled the auto and try to put it in some sort of limp mode? Just curious for all this lol thanks!
no worries about that, the auto transmission is fully mechanical, no electronics.
It's been done but I don't have a link. With a 3FE you can use a 2F or 3F bellhousing, which are found on FJ60s, and a H41, H42, or H55F transmission. ECU don't care. You will need to rewire around the neutral start switch, which is easy. Pedal bucket to have a clutch pedal may be an issue, not sure if you can source one or need to fab something.
The 3FE mates up to the H55 pretty easily, and is comfortably smooth shifting. It makes the tractor motor seem a lot more powerful, but you'll win no races. Unless it's with a D5, you can beat a D5. (On pavement) You might be able to find an H55f on the shelf at Toyota. (NOTE: I haven't been in the market for a while, so I may be wrong.)
if you decide to run the h55 you'll need a splitcase too.
Everyone's covered it. H41/2 (4 speed) can be had for pennies out of a 60 series. H55 (5 speed) you'll need to open up the wallet but the performance will be vastly different. H150 will not pair.
It is and early H150F trans had the correct input shaft for the F series family engines.
Non-US FJ80’s had this combo.
Wow, I would never have known. And that was with same 2&3F bell housing we had here in the states?
I've done a manual swap using a H42 out of a later 60 series. While it did make the truck drive better around town, it was pretty disappointing for me. I don't know why, but I thought switching out the slush box was going to have a lot higher return on the effort. It didn't.
If you're using an H150, the swap is going to cost you close to $5k when it is all said and done, and you may regret it. To each his own, just consider doing a V8 swap of some sort.
Not trying to talk you out of it, per se, just giving you real-world experience with the conversion. I loved the soul of the 3fe, but in the end, the lack of power pushed me to do a V8 swap and I'm so glad I did.
