3FE Lean Mixture problem
Hi all!
I have a 3fe, 1991 and I am stuggling with a lean mixture at idle, leading to low idle RPM. I went to diagnostics today but apart from finding that the idle mixture is very lean and the RPM's get way too low (below 500), they didn't know how to adjust it on this engine. Is there an easy way to make the mixture more rich? They tried rotating a screw which is near the throttle body (the screw faces forward, towards the front of the car) but it didn't do anything. The mixture is fine at higher RPM's, but at idle it is not good and the idle RPM's get low.
I would appreciate any guidance, since i seems that I will have to deal with this myself.
Lean at idle problems often arise from air leaks at the manifold or below the throttle plate. Other possiblities include a mass air flow metering problem and fuel injector problem. This is all described in the trouble shooting part of the factory service manual, which will be your best friend in figuring this out.
Thanks!
I have ruled out the air-leaks-at-the-manifold possibility. It seems in good shape. As for looking for a leak below the throttle plate, I am not sure I understand where to look at, but I will try to find out. The injector hypothesis is also ruled out, since the car has brand new LPG which uses it's own injectors and the problem is still the same on LPG. So, it boils down to MAF or some obscure air leak... Is there a way to manually adjust the way the MAF works or it's airflow?
BTW, I do have the manual and I am trying to work this out with it also, but I have never dealt with engine adjustment before and it takes some time.
You can rule out leaks by looking at the manifold. How do you know it doesn't leak?
LPG is a different can of worms, so that would be useful information in a post. Do you know how the LPG mixture is controlled? Does it rely on the engine electonic sensors?
AFAIK, the MAF is not adjustable. Other sources of vacuum leaks include anything that attaches to the manifold on the engine side of the throttle plate, like the brake vacuum booster, the EGR and the PCV valve.
Well... what other way of checking i have apart from examining it carefully? :)
Yes, it relies on the engine sensors. The way it runs on petrol is the same with LPG, just the set of injectors is different. It gathers it's data from the ECU.
I see, thanks. The EGR is disabled, so I am ruling it out too straight away :)
Poor idle is most commonly associated with unmetered air entering the system. Look for tears/cracks on the intake tube downstream of the AFM. You don't have a MAF but rather an AFM on a 3FE. No good can come from adjusting this. Look for vacuum leaks/clogs.
There are virtually no adjustments to make on this motor as it is computer controlled. You need to make sure the computer is getting the correct base readings from the throttle position sensor and idle speed control valve. This is all in the manual. Once the correct base settings are established, the ECU takes over from there. It does a pretty good job on its own, assuming the rest of the system sensors are working correctly.
The forward facing screw that you adjusted should be turned in all the way and backed out around 3/4 turn or something in that area.
The more reliable method of finding vacuum leaks is to spray propane gas around the outside of the manifold at all of the joints and connections. If the idle improves when you point the gas hose at it, you find the leak.
Mine does the same sometimes and im pretty sure its from the pollution/smog system not working properly. Once i have rebuilt my tranny im going to renew all the parts and hoses.
How is your smog system?
Thanks jonheld and Pin_Head. I will work on it today and post the results.
I have disabled the EGR. I have still not disconnected the smog pump but I will probably do that soon as well. The EGR mod made the car run much better, it didn't solve the rough/low idle issue though.
On second thought... spraying propane at the manifold with a running engine does not correspond well with my idea of safety... :hhmm:
I do not want to blow myself up. Is there an alternative way? Maybe I can spray with CO2?
