3FE Conversion Radiator Hoses
I was thinking that the dash fab and connecting linkage would be more my skill set than wiring around the 40 column.
Well, thanks for the heads up on the links
I would be interested in seeing how you merged the 62 column into the dash. It may be an option for me one day if I see a setup that looks good. I bought a 62 tilt column and a 4-runner non tilt column but ended up not using them. I was after the colapsable column more than tilt. I also desired the extra switched power contact in these ignition switches for the efi but ended up with the 40 column and using a relay instead.
Pretty sure i used fj40 hoses i had to trim the top one a bit
Old thread revival...
Got the part #’s for the upper and lower radiator hoses. Are you guys using the FJ62 hose from the water pump to metal tube for the third hose?
Mine is a 3FE so I used the FJ62 hose from the water pump to the metal tube. If you are doing 2FE, I can't help you there.
Well neither lower hose setup works for me. Looks like I’ll be digging into this further...
Both:
FJ62: (you can see the lower radiator fitting is way off).
FJ45: (Here the lower hose is connected to the radiator and the metal tube is much larger diameter. They don’t line up and the FJ45 hose is too large a diameter. Also I don’t want the heater fitting).
Do I need the metal tube to prevent collapse or can I just remove it and find a suitable hose that goes from water pump to radiator?
I found this picture of the lower in my truck during the install:
Ok the Toyota FJ40 upper works great. An aftermarket “cut to fit” was a no go.
Still not any closer on the lower hose setup. The long 62 hard tube pushes the outlet way too far outboard to even consider using the FJ62 stuff. I’m going to have to do some serious searching to make this work as it should.
Are you guys using a 40 series radiator or 60 series?
I can get you a part number for the bottom hose that we use. I've done 3 conversions and we use the same hose each time. It's cheap and readily available.
I'm about 99% sure it was from a B2000 or a 2600 pickup. We trim them to fit. I use the metal middle tube and then the OEM coolant hose from the water pump to the metal middle tube.
Last motor was out of a FJ62 but we use 80 series stuff with no issues....all fits the same.
Using FJ40 factory AC radiator.
