3FE Conversion Radiator Hoses
Stock 3F hoses cut down a bit....
Top hose was what they have listed there.. BOTTOM? I"m still trying to figure out.
The top hose takes 2 90's.. Bottom I actually might need help with myself!
Thank you for asking! I'm still stuck trying to figure out the lower hose. BUT i'm not sure i had spare FJ62 hoses at the house.. Probably what I drug out of the box were spare FJ0 hoses.
Alright.. I was wrong! top hose is an FJ40 variety which I happened to have sitting at the house brand new cause.. WEll I owned a 40 for a couple decades..
the lower one i am not sure but it would appear the 62 hose might fit! I don't have one can someone confirm!
TOP hose I knoW fits..
so.. First picture.. Hose #2
Second picture I think I want to verify if hose #1 fits the lowest from coupler to lower radiator.. That hose I do not have at the house.. I did purchase an upper FJ62 hose, Which will not fit!
Top hose from my reference is approx 77 fj40. The fj62 hose is in my hand. I have not figured out lower hose yet. But don't have a lower 62 hose here in my pile.
Ordered lower 62 hoses to try tomorrow. If the other guys report back the answer should hopefully be found by tomorrow night.
I dont have an answer for the lower hose yet. Parts monkeys got me 40 hoses from what i can tell. Will try toyota next week.
Not from me. I have a temp hose on mine right now. Have not ordered fj62 hoses. Instead i ordered a borgeson ujoint for my steering and some h55f pieces.
Both bottom? Off 62? Just finishing my shroud hoses are on my to purchase list.
Sent from my phone using IH8MUD
these are the hoses I used:
1657361040 FJ62 lower between metal tube and radiator - had to trim about 1.5" off the long end that attaches to the radiator.
1657160060 FJ40 upper hose.
The rest of the coolant tubes and hoses on the engine are the FJ62 stock.
Thank you.. Just need to swing by toyota.. Course I need both the one between the metal tube and water pump and the lower one. Perfect info..
Im in this swap also how is your going, my dumbass decided to use the steering column out of the
62. Making that look normal in there is trying my patientce. And the wiring has me all nerved out to
Just curious, why did you decide to use the 62 steering column?
For the OP, I used my stock 2F upper hose and a custom hybrid hose down below.
you mean, like this ?
attachment.php
:flipoff2:
thankfully, that's not my truck
you asking about the swap? most of the info is in my thread in the 45 section. I got mine running WAY before I did anything else. Took about 8 hours to cut all the excess wires out of the harness..
Use the 62 harness.. Honestly there's about 5 wires in the harness needed to get it to turn over and run.
Feel free to peruse my thread and other threads on getting the swap to work.
I haven't hit the key in MONTHS tho.. was finishing up other stuff. The little details are what kill you on this swap.
Jeesh.. I used a LOT of zip ties and patience.. a LOT.. un-loom, trace a piece, determine if it was needed, then cut it out.. Patience, a wiring schematic, scapel, zip ties, wire cutter, and patience.
I merged the 45 harness and the 62 harness bits.. Kept the 62 alternator, starter, etc in the mix. Kept the 62 starter switch till it ran then integrated it into the 40 column switch.
I did end up with a HUGE pile of extra wires.. Keep it all zip tied together till it runs then decide if you want to shorten stuff.
Ill post up some pics of my new harness when I get it finished. I started with the 40 harness and kept the 40 column. I initally thought about the tilt or non tilt collapsable column and move the controls to the stalks but opted for the simple 40 look that I really do enjoy. Besides I didn't like the thought of hacking up the dash and didn't like the look of it in the pictures I've seen. Everyone has their own taste. This also way simplified the wiring, trying to retrofit a 62 cowl harness into a 40 would be more trouble than its worth, my opinion.
The harness is 40 years old and POs have done many midnight mods to this thing so I wanted to unwrap it all to verify good wires and connections. Only real damage I found was at the rear of the fuse panel - corrosion and melting due to high resistance connections.
I modified the harness by adding in an extra fuse panel similar to the oem one on the passenger side, to hold the new fuses for the EFI, A/C, stereo, 2M radio, fog lights and air compressor clutch, and incorporated the above related wiring into the harness.
I also took the 8 AWG alternator to battery wire from the 62 harness and used it in the new hybrid harness for the additional capacity alternator on the 3FE. I am building the three required fusible links using 12 and 18 AWG fusible link wire and recycled plastic connector housings.
I modified the rear harness to include wires for the accessories so they can run under the tub and enter up through the floor. I am relocating the ebrake handle to the floor so I had to add wires for the ebrake switch too. Found the ground wire for the fuel level sender not connected to anything.
My plan is to test fit the harness, make final length adjustments, put 12v on it to test all functions on the bench, then wrap with the non adhesive harness wrapping tape.
