- Joined
- Aug 13, 2004
- Threads
- 944
- Messages
- 6,044
what port are you using to supply your turbo?
View attachment 1431753 This port is also pressured. It's found at the back of the block just under the oil cooler It's unused. Don't mind the oily mess... its getting a rebuild.
View attachment 1431669 I often use a brass "T" fitting onto the port the oil pressure sender uses that threads right into the gallery of the right side of the engine. I use the oil pressure sender as opposed to the low oil pressure shut off as often as the engines ages your pressure gradually gets low and you can have the EDIC shut the engine off a few seconds after you start, especially in cold weather. Letting that switch get pressurized quickly can save you a lot of frustration.
My square pegs go into their round holes easily by hand and don't mar any threads and don't leak so I'm ok with them. I've only built a couple dozen 3B turbos over the years but what do I know.
Thanks
g
I have attempted threading in the 1/8th npt with no luck several times. I can't believe you did it gerg.
I kinda agree. I forced a 1/8" NPT into my H block for a mechanical oil pressure sender. Seemed to fit well at first but when I tightened it the brass threads on the fitting that came with the kit stripped right off of it. The BSP-NPT adapters are fairly cheap on Ebay. I just bought 5 of them this week for I think $US3 ea.I have attempted threading in the 1/8th npt with no luck several times. I can't believe you did it gerg.
Well I'm sorry I steered you wrong. I don't know what's up with my block but always better to use to right fitting. Could you post up a link for your fitting? I'll have to buy one to check it out.
Thanks
g
The block oil fittings on Toyota engines (as well as most Japanese engines) are NOT your standard NPT threads--they are also NOT metric threads. They are BSP (British Standard Pipe). The sender unit is a 1/8in X 28BSP. It is 1/8" in diameter with 28 threads per inch.
The 1/8in NPT fittings have 27 threads per inch. The threads on BSP versus NPT are cut with threads with a 5deg difference in angles. The depths of the threads are also different due to the shapes of the peaks and valleys. The correct male BSP fitting is also tapered. The only thing that happens to fit with an NPT fitting is the 1/8in diameter--otherwise, you might as well just drive a square peg into a round hole.
The correct 1/8in x 28BSP to 1/8in NPT adapters are available from Amsoil, Autometer, and Mcmaster-Carr. From there you can add whatever T or elbow fittings you need.
The other question you should ask if you are adding a turbo is "what are you using for an oil return?" The return is just as important as the supply. FWIW, having talked with two manufacturers, the return should only flow unimpeded, by gravity, straight down to the oil pan. It should never be plumbed in to any other return line, or run back into the valve cover or top of the engine.
