37" swampers mounted
put these on the other day. used.
notice that I sleeved the drag link
new brembo discs
remanufactured calipers
new tre's (the front end is much tighter)
new bearings/seals
1 chinese birfield
quick disconects
rear swaybar is getting trashed
even with a turbo I need to regear high range with these 37's
tomorow I head to shaver lake for 4 days to try it out around bald mountain. if anyone will be there let me know
You are gonna love em. You can roll over what you used to fear :)
this is my hope. my biggest discomfort right now with this truck is boulder fields. I hope this big meats make the big boulder streams more pleasant. I have increased rear bumps to 4" and have finally added the slee 2" bump extenders to the front but Im willing to compromise a little uptravel towards this experiment.
i have slee 4" springs front and j's in rear in a truck with no winch weighing 5,800lbs with tools and full spares. (this was with 35's). I removed front mud flaps. did a little trimming with flares. running tundra/tacoma steelies with an extra 1.5" wheel spacer which should equal a 3 inch backspacing. we shall see brethren we shall see....
the swampers are noisy as hell but ride smooth as glass-much better than the mtr's. But a diff shop ballanced the swampers and now the front end has new tre's and all new bearings including trunions. the new rotors have no shimmy when stopping
the truck used to have a vibration after the lift at certain rpms. possible the drivelines. but this is now gone. i wish i had replaced this tre's when i bought the truck
Looks awesome. What front bumper is that?
oh yeah...if you play in the rocks with 37s I would grab some longfields and poly rears...and prepare for the rear locker explosion :)
What do you do with the caster problem?
The tires are Super Swamper SSR 37x12.5R17?
You don't have vibrations in Highways?
Looks skinys like 11.5 but could be to a norrow wheel .?
I use the innovative balancing product called dynabeads...works great on my 37" Iroks, just had to go to 14 oz due to the weight of the swamper.
isn't that a little high.... on the chart, if i'm reading this right (and that is a big if) my 36" wrangler oz tires only require 8oz :confused:
tires are 37 12.5 16 swamper radials
caster is slee blue bushings. tracks great
wheels are 16x7 toyota
they were ballanced well till this trip now are unballanced. i had them down to 12psi for a half day with 800+ lbs of adults. this chunked rears. i then aired them up to 25psi to do the boulders at westlake. i will be buying beads soon
truck is a whole diff animal with 37's. i will never wheel 35's with this truck again. we did the easy side of bald mountain (shown in video). Then climbed the harder side. then did westlake. the boulders of westlake were so easy with more clearance. needs 5.29's but if you arn't hitting stuff under truck the gearing issue isn't so bad. used less lockers. i have oe radius arms and these tires hit at the rear of front fender wells on stuffage + turning. hammer will fix or slee arms. I need 39's
did action jackson run oe locker in rear or did he do ARB?
for those considering these tires remember that mine are used. I dont guarantee results
http://video.google.com/videoplay?docid=-4275835139807397322&hl=en
Your balance issue may not be the chunking...I have the same tire on a factory 80 wheel. When the tires are aired down below 15psi. I have a problem with the tire spinning on the rim. Makes for an interesting ride home.
37's are only an inch bigger than 35's. You really noticed an improvement?
