So after reading everything I can find on here and looking at the wheel/lift/tire chart I'm a bit confused, it seems as though people are shocked when a 200 has 35's on it?!?! with a 2.5 or 3 inch lift do 35's not fit? I'm guessing brand of tire and offset and width of wheel would also affect it... But my basic question is will a 35x12.50 fit on a 200 series assuming lift and wheels are correct?!?! And if they don't fit where are the problems? front inner fender can easily be cut out, pretty much just a mud flap and plastic... Upper control arm issue can be fixed with after market UCA and wheel with more offset, right?!?! Lower KDSS arm might be an issue, could be solved a bit by a wheel with more offset but still may be an issue?!?! Rear tire could rub on frame? Wheel with more offset could help this too... Just thinking out loud... I guess a wheel with a larger offset could put the tire/wheel out far enough that it may not tuck properly and run on top of fender??? thanks in advance for any feedback....
Kreiten
Kreiten
Don't forget, if you have the diffs pulled, you might as well add lockers while they are apart. Add another $1300 - $1500 per axle to your parts and labor fund.
