Starting to gather some good info here. Thanks! Sounds like 35x12.5 might be a good compromise. If I had my druthers I'd go 35x13s. I believe the duratracs come in that size along with toyo at2. I know with my 33x13s it is really close to hitting the sway bar at full lock and I'm running an 18x9 18+ wheel . Definitely would require an actual cut into the factory bumper which I want to avoid. Don't want to run any heavy aftermarket bumpers either.
Trail grapplers are a good tire too since nitto is a sub brand owned by toyo. Good looks to boot.
Did you regear?
@Atwalz I’ll be interested to hear a review from you on a drop bracket lift.
In my past, they proved over and over to be one of the worst suspensions for an off road truck. Higher center of gravity with the same crappy articulation. Trucks would constantly be so much more iffy when on trail rides.
But... the 200, as we know, feels unlike any other Toyota when off road. Tacoma’s, 4Runners, and FJs feel like you wheel IN the rocks. 200s feel like you wheel ON the rocks.
So maybe this will be a good option, I’m genuinely interested.
LOVE IT! What a BEAST, Rubicon ready!@kreiten after several years, I now have fitted 35s KO2 on methods mr704 bds 4.5” tundra lift front w/Fox Coilovers + dsc and tundra axle/arm conversion. Front fenders are trimmed. Body mount chop was not necessary. Front track width is ~82”. Rears springs are tough dog tour flex heavies. I will add spring spacer for extra lift on rear axle. No rubbing on front. Rear bump stops needs to be dropped slightly. Overall height is slightly less than 7ft.
