32 spline pinion
I was browsing the Web and found the build of the Nitro axle cruiser. Apparently the 70 series they built uses a 80 rear axle with a 32 spline pinion and 32 spline shafts. I think the stock 80 axle has 27 spline. 32 spline would've quite a nice upgrade. Anyone done this? This would take a fj80 rear axle beyond Dana 60 strength I believe. They also apparently used 32 spline shafts for the front axle. Is this a kit Nitro sells?
The 100 series uses 32 spline shafts and third, I would imagine they retrofitted a rear 100 series third to get the larger shafts. Not sure about the pinion and the front everything must have been custom. They must have rebroached the carrier, I am guessing they used an ARB?
I know 35 spline axles can be done on the rear 80 axle. It would be sweet to have the 32 spline pinion with 35 spline axles. But 32 spline axles would probably be strong enough for my uses. If I see the Nitro 70 again I will ask the guy more questions. Not sure why they don't advertise these modifications much. Upgrading to 1ton axles adds a lot of weight.
