31" or 33" Tires on 1977 FJ40
So, you had no problem running 33x12.50x15 with the OME Spring lift, correct? Any issues or conflicts with the steering arm or pitman arm? Do you think it’s possible to run a 34X9.5X15 with the same setup?
Correct, I had no issues running the 33x12.50 with the OME lift......However, I downsized to a set of 32x11.50 not long after installing the 33's.
I don't believe 34's would be advisable to run on a 2" lift like I have.
Ya know, if it’s the stock wheels, it may fit, but I guarantee some rubbing, look at the actual size, may only be like 33.4” tall
hello JeffD, is there a lift installed on the 40? what size are the rear shackles? are those stock springs? thanks
4” lift, not sure the brand. Everything was on there when I bought it years ago. I assume the springs are stock, previous owner did the shackle reversal on the front, rear shackles are about 6”. If you want me to measure anything, let me know? Here are a couple more recent pics if that helps at all.
