Any diesel shop that can cross reference a Denso part should have no trouble getting them.. wort case I know the Portland diesel shop had no trouble getting me mine Coming Soon – Diesel Fuel Injection Services - https://dfispdx.com/Anyone recommend where to get injector nozzles? They are all leaking and bad spray patterns.
Hey that’s not a bad idea. Where did you get your injectors from? I was going to get OEM nozzles from megazip, and that was gonna run me $200~ CAD.Nice work! With all that money and effort in the long block, I'd highly recommend just buying rebuilt injectors that are ready to go. I played around with rebuilding mine, and they weren't that reliable. I was really careful. Also, make SURE you replace the nozzle crush washers in the head, otherwise the injector nozzles get sooted up and over heat and go all to sh!t. Might be why my diy rebuilt injectors had issues, lol. Anyhow, I always use new nozzle washers when I have injectors out how. The other washers can be re-used tho. I ended up buying brand new oem Toyota injectors. Was totally worth it.
I remember seeing one of your threads about the throttle nozzles vs regular ones. I know my diesel is way clackier then my friend’s 90s model one so I assume I would try and get the regular type injectors.Hey that’s not a bad idea. Where did you get your injectors from? I was going to get OEM nozzles from megazip, and that was gonna run me $200~ CAD.
Right on!Quick update. I've sourced a set of OEM reman injectors from a machine shop out by Kamloops. $500 and some change + send my old ones back as cores. Not bad.
Okay yeah I’ll dump the 15w40 and run some 10w30 for the break in period. I’m noticing it was hard to start today, needed basically full throttle to get going, with a noticeable stumble. Running pretty rich too. I’ll send a video later. I don’t start it anymore until I can run it around and seat the rings.Congratulations!!! That's great! Sounds excellent to me
Run a basic 5w30 or 10w30 dino oil for breakin maybe? Definitely no synth. Make sure to take it up some good long highway grades to load it up steady for a while. Diesels need that to set rings properly.
I ruined a set of cam bearings in my motor starting at -25c with 15w40. Oil was so thick, the bearings were starved. Filled my oil with sparkles. So get that 15w40 out of there till late spring!!!
And the stumble
