2fpower's going to build a camping trailer
You want your hinge to be the fuse. Get aluminum in case you ever catch the door on something.
I disagree with the "Fuse" concept in general. There are places where it is appropriate, like in electrical, but rarely anywhere else. Design the doors so that they can open 180° or nearly so.
I'd go with SS for corrosion resistance. A good way to bend a door is a corroded set of hinges or piano hinge. Unless it is hard anodized aluminum, which I highly doubt, it too will eventually corrode and try to seize where the SS won't.
It looks like you're making the boxes out of aluminum? So I'd go with the aluminum hinge to prevent galvanic corrosion. Dissimilar metals are going to be an issue where they join.
Oh, spaced on that aspect. Yeah w/o a dielectric between the SS hinge and the aluminum body any moisture in there between them forms a destructive battery. Zinc or Cad plated steel is actually a better choice than SS for this.
What is the plan for coating the body? If going to be power coated or POR-15'd and then the hinges screwed into place I wouldn't worry about using the SS hinge. If going to be "normally" painted or left bare then this is a concern.
Well you had me talked into stainless, but given that comment I’ll go back to aluminum
First goal today was to get the design finalized for the door area pieces to get bent up. I received the roll of weatherproofing yesterday that @ntsqd recommended, so came up with this design using 1/8 stock.
1900911
1900912
Worked today to cut out all the doors and the front box to have the Metal Shop bent things this week.
1900913
Here is the cardboard cut out for the front storage box.
1900915
And the stack of all the pieces to take to the shop:
Big rear door, one side door, two sides for front box, front stub for box, and box bottom. Plus material for some angle pieces to span the entire top for the roof rack mount. only part I did not make was the lid to the box; however, I am going to wait to do that after I have the opening completed.
1900914
Went over to @kc_chevota shop and broke his finger brake... working on the fenders.... thanks also to jack too. Took three of us to get the 3/16 aluminum to bend ....
1901864
Here is his finger brake I helped him get years ago.
1901862
1901863
1901864
1901863
Raises it on the lift, like the lack of the solid axle
1901862
I emailed austin hardware, and they came back with this email that let me to an online catalog that was much more helpful than thier website....
On our paddle handles the max distance between the flange and the striker bolt is Around .89”, nothing around an inch. We do have T-Handles that are adjustable and have enough range.
Austin Hardware Catalog - Pages 1 - 284
I am trying to decide now if I just want to get tamper resistant locks on this (like the ones on the electrical enclosure) and a small handle versus the paddles.
Been thinking about the design of the pull out kitchen....
So I decided to model one out of cardboard
Got to work on the fenders today, really happy with how they turned out, They also are strong enough to bring out the deflection on the side walls of the main box. spent a bunch of time dialing in this pool gun, very happy with how it welds now
The Metal Shop called, and had bent up all the stuff. Lots of stuff to start working on. You may notice that the door sides are bent back about an inch and a half, which is way too long, that was the minimum leg that the shop could do. I’ll trim all these down on my tablesaw. ATTACH=full]1914149[/ATTACH]
Found these "roller hinges" on ebay/amazon. much like the normal latch, but the latch part is rubbe and "rolls" across the latching surface. Really like the idea of this thing not clanking all the time, so thought it would be a good idea.
1914513
1914512
Found some time today to start to weld up the front box. Really enjoying the spool gun.
Doors coming along.
1919471
1919472
1919473
1919474
1919476
Got doors on.....
1922515
1922516
1922517
1922518
Got the side door welded to the hinge, and install the weatherstripping....
1923438
Then started to test where to install the door handles
1923439
1923440
Finally made a jig so I can quickly plasma cut out these holes....
1923441
rear door is basically done...
1924650
Worked on the door opening for the box that will be bolted to the side for kitchen supplies
1924651
And got the lip welded on for the front box. I ended up tapering the top upwards half an inch at the center and then angling the trim down to wash away any rain tickets behind the hinge
1924652
1924653
