2f water pump question
I am planning to put an flex lite puller 165 electric fan . This is the sample pic of the water pump that is in my 2f. Can this be shorten to give room for the electric fan.
The answer is no. The pump also sets the spacing for the pulley, and the belts must stay parallel.
How old is your radiator? What temp does your thermostat open at? Have you considered the 8 blade fan? I have those on sale.:grinpimp:
so the electric fan in your case is a band-aid.
i'd bet money your clutch needs looked at.
Hi My cruier is in the Philippines . When i went home and drove it temp went up its pretty hot ,the thermostat has been removed. I am using an aluminum radiator which is a year old. Temp goes up once i am in traffic on idle. Have not seen your 8 blade fan
You know, I just went to my website and I couldn’t find it either! D’oh. It’s $40. Made my 40 sound like the UPS truck going down the street.
A bad radiator cap is also a possibility, and if you don’t know how old yours is, something I’d put at the top of the list to replace.
... the thermostat has been removed. ...
The 2F motors (at least the ones we get) all have a bypass cooling system. If run without the thermostat, will not warm up correctly, and will bypass a large percentage of the coolant flow, so when stressed will easily overheat. A properly setup thermostat with both the gasket and o-ring, will outperform in both correctly warming up and having much greater cooling capacity. There is zero advantage or reason to run without a thermostat, all it does is cripple the cooling system.
Pics would be nice
Tks will reconsider
Butch- I think this is the 8 Blade Mark’s Off Road is recommending. I’ve read he also offers a correct spacer for his customers. I imagine he could also hook you up with the correct thermostat and cap. Might not hurt to scuff up your belt pulley’s with a green scotch brite pad while your at it.
Can i get a quote for the 8 blade ,cap, upper radiator hose plus shipping to 91311
I’ll try and do that later today Joel. Upper hose changed over the years. What year is yours?
