2F valve adjustment
Virginia Beach
Last night I started do an initial cold valve adjustment (after installing the head). After I completed I rotate the crank twice to verify smooth operation and found that some of the valves were not properly set (cm gap). I’ve never done this procedure before and the manual reads simple enough, so I’m not sure what I’m doing wrong or if something is broken.
I’m still searching the forrums and YouTube
did you forget to put a push rod or two back in?
not sure it's possible to have that much clearance with the valve train bolted down.
No everything is there, I’m hoping to try again today if I can get my yard work done first.
I have come across that thread a couple times. I don’t believe I’ll ever try while running.
Yesterday I got some time between work and picking up my boy form daycare. I started out just verifying the outcome of the first attempt. Loosen everything back up. Rotated the crank one rotation so that timing was 180 out and started my adjustments. When complete I was happy with everything so I pulled and re intalled the distributor to match..
where I screwed up the first time, I installed the distributor not thinking of the cam position and rotation ratio of the cam and crank. So when I thought I was at TDC for the 1st cylinder I was on the wrong stroke. I’m hoping to finish the rest of the engine compartment this week. And verifying the alignment after it heats up.
Out of curiosity how often does the alignment need verifying for regular maintenance?
