2F Heritage!??!?
Good to know, always wondered how that worked! :D
I just discoverd a cam gear that had walked, enough to push the freeze plug out the back, but it ran like a top. :rolleyes:
Here are some more...
I'm gonna back away from my comment about it looking fubar. From these pictures it appears that the wear patrtern is very very shallow? More of a light scuffing of the surface than any actual removal of material? Check it with a straight edge. The lifter should be crowned a little bit (convex). If it is perfectly flat at 20,000 miles that is okay. But if that worn looking area is lower than the surrounbding area, that's a bad thing.
The first picture appeared to show some pitting near the edge of the lifter face. I don't see it in the other shots. ???
It still looks like it is not rotating. If you can get a good look at the cam lobe, how does it look?
Mark...
As far as the original thread topic, the story I've heard is basically a composite of what Mark and Ige said.
As far as the lifter thing goes, it doesn't take much of a burr in those holes on the side of the lifters to keep them from rotating. I'd want to check in the bore of the block for signs of a singularly large groove. I'd chamfer those holes before I reinstall the lifters just for good measure.
